hi, i have some dht22 connected to an esp32 that sometimes freeze and go into error.
Esphome detects the error with " Invalid readings! Please check your wiring (pull-up resistor, pin number) ".
Is there a way to use a lambda expression and the on_value function to avoid sending the Invalid reading error to homeassistant and instead remains the last value read correctly?
i try with:
- platform: dht
model: DHT22_TYPE2
pin: GPIO19
temperature:
on_value:
lambda: |-
if (!(isnan(x))) {
id(dht22_t1).publish_state(x);
humidity:
update_interval: 120s
but the esp32 explodes and becomes unreachable
