I’ve already opened a Github issue these days, but I’m sure a few more people will drop by here who might be able to help me/us with the current challenge.
What happened?
If I enter a value for Transition, no transition is executed by the lamp, and the lamp no longer switches off if any value is entered for Transition (see point below: reproduce)
What did you expect to happen?
The transition is applied when it is set. The request would be to find a technical solution or workaround for this, as the manufacturer has created something incorrectly. I have also written to the manufacturer, but so far no response. I have installed 20 lamps in my house and am very unhappy at the moment and would really appreciate some help. If there is any way to find a solution, please help me find out exactly what needs to be entered.
How to reproduce it (minimal and precise)
Transition if you enter a value 0,1,2,3 the lamp no longer switches off. Transition is not supported. The field must be left empty, only then is proper operation possible, but without transition.
