Blueprint
AWTRIX 3
via native MPPT on Home Assisant set on Ubuntu
native MPPT
your solar device integrated into AWTRIX
ok. got it. no ideas tbh.
selector:
device:
integration: mqtt
manufacturer: Blueforcer
model: AWTRIX 3
multiple: true
blueprint trying to grab all device manufacturer by Blueforcer with model AWTRIX 3
so, if you what help me and yourself you can comment
in bprint
selector:
device:
integration: mqtt
# model: AWTRIX 3
multiple: true
reload in HASS automation and see what right now
@10der Do you know if it is possible to have a static clock app that shows the clock and a sensor value? ie something like [10c 10:46]
I can see a way to push the updates from home assistant every 60 secs but Iād prefer to not rely on the wifi connection etc to update the clock. So is it possible to use the clock in the device as a value and push the value from the temp sensor in HA?
Interesting⦠let me check
alias: AWTRIX - TEST - DEL ME
description: ""
use_blueprint:
path: 10der/awtrix-simple.yaml
input:
awtrix_device:
- eb5a6a7b7cdea5bb00cf794599e8fc17
user_options:
duration: 1
text: ""
draw:
- dt:
- 0
- 1
- "{{value_temperature}}°"
- "{{color}}"
- dt:
- 12
- 1
- "{{time}}"
- "#FFFFFF"
app_name: awtrix_app_del_me
entity: sensor.home_temperature
additional_options:
colors:
"0": "#00ff7f"
"5": "#00ff2a"
"10": "#2aff00"
"15": "#7fff00"
"20": "#d4ff00"
"25": "#ffd400"
"30": "#ff7f00"
"35": "#ff5f00"
"-15": "#007fff"
"-10": "#00d4ff"
"-5": "#00ffd4"
value_temperature: "{{states(entity_id) | round(0, 'floor', 0) }}"
color: |-
{{colors[(colors.items() |
map(attribute='0') |
map('int') |
sort | select('>=', value_temperature ) |
first) | string]}}
time: "{{ now().strftime('%H:%M') }}"
extra_triggers:
- trigger: time_pattern
minutes: /1
do not try to pass āevery secondā and implement blinker
{{ now().strftime('%H') }}{{ ':' if now().second % 2 == 0 else ' ' }}{{ now().strftime('%M') }}
it will be overhead.
btw: you canāt mix default clock app with own data.
Here is a node red flow that replicates the default clock with customisations.
Just import into node red to use, temperature could be added
[{"id":"aa0f712d4983c11b","type":"group","z":"c29e36f478fc3db8","name":"Clock and Calendar","style":{"label":true},"nodes":["18a56279.3119a6","b04e8bae.ac1f","593cd673.a975a"],"x":114,"y":2379,"w":1172,"h":82},{"id":"18a56279.3119a6","type":"function","z":"c29e36f478fc3db8","g":"aa0f712d4983c11b","name":"Format LCD","func":"const hoje = new Date()\n\nvar dia = hoje.getDate() \nvar diaDaSemana = hoje.getDay()\nvar hora = hoje.getHours()\nvar minutos = hoje.getMinutes()\nvar corDiaSemana = \"#09d602\" // color for current day of the week\n\nif (diaDaSemana == 0) {\n diaDaSemana = 0 // conversion to monday starting week\n corDiaSemana = \"#d60202\" // red mark for sunday\n}\n\n// add leading 0 to days, hours and minutes <10\nif (dia<10) {\n dia = \"0\" + dia\n}\nif (hora<10) {\n hora = \"0\" + hora\n}\nif (minutos<10) {\n minutos = \"0\" + minutos\n}\n\nmsg.payload = \n\n{\"draw\":[ \n {\"df\": [1,2,9,7, \"#FFFFFF\"]}, // draws day of month box \n {\"df\": [1,0,9,2, \"#FF0000\"]},\n \n {\"dt\": [2, 2, dia, \"#000000\"]}, // draws day of month\n {\"dt\": [13, 1, hora + \":\" + minutos, \"#FFFFFF\"]}, // draws the clock\n \n {\"dl\": [11,7,12,7, \"#666666\"]}, // draws days of week markers\n {\"dl\": [14,7,15,7, \"#666666\"]},\n {\"dl\": [17,7,18,7, \"#666666\"]},\n {\"dl\": [20,7,21,7, \"#666666\"]},\n {\"dl\": [23,7,24,7, \"#666666\"]},\n {\"dl\": [26,7,27,7, \"#666666\"]},\n {\"dl\": [29,7,30,7, \"#666666\"]},\n {\"dl\": [11+(diaDaSemana)*3,7,12+(diaDaSemana)*3,7, corDiaSemana] // draws current day of week mark\n } \n],\n \"pos\": 1,\n} \n\nreturn msg;","outputs":1,"timeout":"","noerr":0,"initialize":"","finalize":"","libs":[],"x":870,"y":2420,"wires":[["b04e8bae.ac1f"]]},{"id":"b04e8bae.ac1f","type":"mqtt out","z":"c29e36f478fc3db8","g":"aa0f712d4983c11b","name":"App Data Clock","topic":"awtrix_lounge/custom/clockCalendar","qos":"2","retain":"false","respTopic":"","contentType":"","userProps":"","correl":"","expiry":"","broker":"34f7583aa6e3efb2","x":1180,"y":2420,"wires":[]},{"id":"593cd673.a975a","type":"inject","z":"c29e36f478fc3db8","g":"aa0f712d4983c11b","name":"1x/min","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"*/1 0-23 * * *","once":true,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":220,"y":2420,"wires":[["18a56279.3119a6"]]},{"id":"34f7583aa6e3efb2","type":"mqtt-broker","name":"core-mosquitto: 1883 192.168.2.40","broker":"core-mosquitto","port":"1883","clientid":"","autoConnect":true,"usetls":false,"protocolVersion":"4","keepalive":"60","cleansession":true,"autoUnsubscribe":true,"birthTopic":"","birthQos":"0","birthPayload":"","birthMsg":{},"closeTopic":"","closeQos":"0","closePayload":"","closeMsg":{},"willTopic":"","willQos":"0","willPayload":"","willMsg":{},"userProps":"","sessionExpiry":""}]
The key Javascript code in the flow, can be modified to add temp.
const today = new Date();
let day = today.getDate();
let dayOfWeek = today.getDay();
let hour = today.getHours();
let minutes = today.getMinutes();
let weekDayColor = "#09d602"; // default color for current weekday
if (dayOfWeek === 0) {
// If Sunday, treat specially (if your week starts Monday)
dayOfWeek = 0; // keeps Sunday as index 0
weekDayColor = "#d60202"; // red highlight for Sunday
// Add leading zeros for single-digit day, hour or minutes
if (day < 10) {
day = "0" + day;
if (hour < 10) {
hour = "0" + hour;
if (minutes < 10) {
minutes = "0" + minutes;
msg.payload = {
draw: [
{ df: [1, 2, 9, 7, "#FFFFFF"] }, // draw box for day of month
{ df: [1, 0, 9, 2, "#FF0000"] },
{ dt: [2, 2, day, "#000000"] }, // draw day-of-month text
{ dt: [13, 1, hour + ":" + minutes, "#FFFFFF"] }, // draw clock text
{ dl: [11, 7, 12, 7, "#666666"] }, // draw day-of-week markers
{ dl: [14, 7, 15, 7, "#666666"] },
{ dl: [17, 7, 18, 7, "#666666"] },
{ dl: [20, 7, 21, 7, "#666666"] },
{ dl: [23, 7, 24, 7, "#666666"] },
{ dl: [26, 7, 27, 7, "#666666"] },
{ dl: [29, 7, 30, 7, "#666666"] },
dl: [
11 + (dayOfWeek) * 3,
7,
12 + (dayOfWeek) * 3,
7,
weekDayColor
} // draw current weekday marker
pos: 1
return msg;
The key from topic starter - assistant every 60 secs but Iād prefer to not rely on the wifi connection etc to update the clock.
So, if Wi-Fi is dead your node red task for clock is dead as well
Thanks. The app above works brilliantly, but it still relies on Home Assistant sending it every 60 secs
I have gone through the code on github and I canāt see the system time value being surfaced anywhere (I may be missing something though).
but again: native apps doesnāt have any dynamic api options. you canāt mix own data and clock time.
so, you can simple disable calendar in time app via TMODE but (again) you canāt draw own data in place of calendar.
alas
Can you share the Blueprints for the http Brigde? Thanks!
Hi, Iām experimenting with your new integration.
Can you please show how to use the new awtrix3-simple.yaml blueprint to show different colors for an outdoor temperature sensor like the first example given in this thread for the old integration?
Tgx
maybe I am not catching your question.
but all user code is compatible with old (mqtt) and new (http) blueprint.
so you can simple use code from example
I made it work. Thanks
hint:
alias: AWTRIX - HOME_TEMPERATURE
description: ""
use_blueprint:
input:
app_name: awtrix_app_home
suffix_text: °
awtrix_device:
- cba036557ec6a93c46e1772448fac471
app_icon: "96"
user_options:
color: "{{color}}"
additional_options:
value_template: "{{states(entity_id) | round(0, 'floor', 0) }}"
color: |-
{% set temp = value_template | float %}
{% set t_min, t_max = -15, 35 %}
{% set h_min, h_max = 240, 0 %}
{% set t_clamped = [ [t_min, temp] | max, t_max ] | min %}
{% set ratio = (t_clamped - t_min) / (t_max - t_min) %}
{% set hue = (h_min + ratio * (h_max - h_min)) | int %}
{% set h = hue / 360 %}
{% set s = 1.0 %}
{% set v = 1.0 %}
{% set i = (h * 6) | int %}
{% set f = h * 6 - i %}
{% set p = v * (1 - s) %}
{% set q = v * (1 - f * s) %}
{% set t = v * (1 - (1 - f) * s) %}
{% if i % 6 == 0 %} {% set r, g, b = v, t, p %}
{% elif i == 1 %} {% set r, g, b = q, v, p %}
{% elif i == 2 %} {% set r, g, b = p, v, t %}
{% elif i == 3 %} {% set r, g, b = p, q, v %}
{% elif i == 4 %} {% set r, g, b = t, p, v %}
{% else %} {% set r, g, b = v, p, q %}
{% endif %}
#{{ "%02x%02x%02x" | format((r*255)|int, (g*255)|int, (b*255)|int) }}
prefix_text: "{{ '+' if value_template > 0 }}"
extra_triggers:
minutes: /15
Hey
Have this auto:
alias: AWTRIX Temp Inde
description: ""
use_blueprint:
input:
entity: sensor.aqara_temp_rum_a_temperature
app_icon: "2355"
prefix_text: "{{ 'Temp +' if value_template | int > 0 else 'Temp ' }}"
additional_options:
colors:
"0": "#00ff7f"
"5": "#00ff2a"
"10": "#2aff00"
"15": "#7fff00"
"20": "#d4ff00"
"25": "#ffd400"
"30": "#ff7f00"
"35": "#ff5000"
"40": "#ff2000"
"-15": "#007fff"
"-10": "#00d4ff"
"-5": "#00ffd4"
value_template: "{{ states(entity_id) | float(0) | round(0) | int }}"
color: >-
{% set value = value_template | int %} {% set keys = colors.keys() |
map('int') | sort | list %} {% set match = keys | select('>=', value) |
list | first %} {{ colors[match | string] if match is not none else
colors['40'] }}
user_options:
duration: 5
color: "{{ color }}"
awtrix_device:
- 74e0154505fe3586e7ad399f749be8b2
But i get this error:
The automation "AWTRIX Temp Inde" (automation.awtrix_del_me) has an unknown action: awtrix.awtrix_push_app_data.
This error prevents the automation from running correctly. Maybe this action is no longer available, or perhaps a typo caused it.
To fix this error, edit the automation and remove this action.
Select Submit below to confirm you have fixed this automation.
Why??
- wrong device name?
- renamed device?
i can`t chose another device,it is the right
