AWTRIX NG Sensor Display – colour thresholds, progress bar, scrolling text & weather overlay [DE]
What it does
Displays any Home Assistant sensor as its own app on an AWTRIX NG pixel panel, updated live over MQTT whenever the sensor’s state changes. No Berry app, no MQTT statestream — just pick a sensor and an AWTRIX device, and it works.
Features
  • Pick your AWTRIX panel from a device dropdown — no manual MQTT topic typing (the topic is read live from the panel’s own MQTT-prefix sensor)
  • Text colour with two configurable thresholds (e.g. blue below 10°C, green in between, orange above 22°C)
  • Full scroll control: mode, speed, direction, entry, gap, hold time
  • Background effect and animated weather overlay
  • Progress bar for percentage-style sensors (humidity, battery, print progress, etc.)
  • Auto-hides the app if the sensor stops updating (configurable lifetime)
  • Optional: also set the device-wide app transition effect
Requirements
  • AWTRIX NG firmware (not AWTRIX 3 — different API, this blueprint will not work on AWTRIX 3)
  • An MQTT broker that both Home Assistant and AWTRIX are connected to
  • Home Assistant MQTT discovery enabled on the AWTRIX device (Settings → MQTT in the AWTRIX web UI) — needed for the device dropdown to find your panel
Source / updates
GitHub repo (issues and PRs welcome): GitHub - Heronidas/ha-awtrix_ng-sensor-display: Home Assistant blueprint that displays any sensor as a live app on AWTRIX NG pixel panels via MQTT — with color thresholds, scrolling text, progress bars, and weather overlays. · GitHub
Blueprint code
blueprint:
  name: AWTRIX Sensor-Anzeige
  description: >
    Zeigt einen Home-Assistant-Sensor als eigene App auf einem AWTRIX-NG-Panel
    an. Aktualisiert sich automatisch bei jeder Änderung des Sensorwerts,
    direkt per MQTT - keine Berry-App und kein Statestream nötig.
    Enthält: Textfarbe mit Schwellenwerten (z. B. grün/orange/rot je nach
    Wert), Laufschrift-Feinsteuerung, Hintergrundeffekt, Wetter-Overlay,
    Fortschrittsbalken, automatisches Ausblenden bei veralteten Werten und
    optional den geräteweiten App-Übergang.
  domain: automation
  author: Ingmar
  source_url: https://raw.githubusercontent.com/Heronidas/ha-awtrix_ng-sensor-display/main/awtrix_sensor.yaml
  homeassistant:
    min_version: "2024.10.0"
  input:
    quelle:
      icon: mdi:eye-outline
      input:
        sensor_entity:
          description: Der Home-Assistant-Sensor, dessen Wert auf dem Panel erscheinen soll.
          selector:
            entity:
              domain: sensor
    geraet:
      icon: mdi:led-strip-variant
      input:
        awtrix_device:
          description: Auswahl aus der Geräteliste - kein manuelles Eintippen des MQTT-Topics nötig.
          selector:
            device:
              filter:
                - integration: mqtt
                  manufacturer: Blueforcer
                  model: AWTRIX NG
        app_name:
          description: Interner Name für diese Anzeige auf dem Panel. Nur Buchstaben, Zahlen, "_" und "-", keine Leerzeichen.
          selector:
            text: {}
    anzeige:
      name: Text & Anzeige
      icon: mdi:format-text
      input:
        unit:
          description: Wird direkt an den Wert angehängt, z. B. "°C" oder "%".
          default: ""
          selector:
            text: {}
        icon_id:
          description: LaMetric-Icon-ID, die bereits auf dem Panel installiert ist. Leer lassen für kein Icon.
          default: ""
          selector:
            text: {}
        center:
          name: Text zentrieren
          description: Nur wirksam, solange der Text steht (siehe "Text, der passt" bei Laufschrift).
          default: true
          selector:
            boolean: {}
        text_case:
          default: "inherit"
          selector:
            select:
              mode: dropdown
              options:
                - value: "inherit"
                  label: "Geräte-Standard übernehmen"
                - value: "upper"
                  label: "GROSSBUCHSTABEN erzwingen"
                - value: "asTyped"
                  label: "Genau so anzeigen wie eingegeben"
        duration_sec:
          description: Wie lange diese App pro Durchlauf zu sehen ist. 0 = Geräte-Standard verwenden.
          default: 0
          selector:
            number:
              min: 0
              max: 60
              unit_of_measurement: s
              mode: box
    laufschrift:
      icon: mdi:format-pilcrow-arrow-right
      collapsed: true
      input:
        scroll_mode:
          name: Verhalten bei langem Text
          description: Was passiert, wenn der Text nicht komplett aufs Panel passt.
          default: "wrap"
          selector:
            select:
              mode: dropdown
              options:
                - value: "wrap"
                  label: "Durchlaufen, dann von vorn beginnen"
                - value: "loop"
                  label: "Gleichmäßig durchlaufend, ohne Sprung"
                - value: "bounce"
                  label: "Hin und her pendeln"
                - value: "static"
                  label: "Nicht scrollen, Rest abschneiden"
        scroll_speed:
          description: 100 % = normales Tempo, 0 % hält den Text an.
          default: 100
          selector:
            number:
              min: 0
              max: 300
              step: 10
              unit_of_measurement: "%"
              mode: slider
        scroll_direction:
          default: "left"
          selector:
            select:
              mode: dropdown
              options:
                - value: "left"
                  label: "Von rechts nach links"
                - value: "right"
                  label: "Von links nach rechts"
        scroll_entry:
          name: Start des ersten Durchlaufs
          default: "inline"
          selector:
            select:
              mode: dropdown
              options:
                - value: "inline"
                  label: "Sofort an Ort und Stelle sichtbar"
                - value: "offscreen"
                  label: "Läuft von außerhalb ins Bild"
        scroll_when_fits:
          name: "Wenn der Text passt"
          description: Betrifft nur kurzen Text, der gar nicht scrollen müsste.
          default: "static"
          selector:
            select:
              mode: dropdown
              options:
                - value: "static"
                  label: "Ruhig stehen bleiben"
                - value: "scroll"
                  label: "Trotzdem einmal durchlaufen"
        scroll_gap:
          name: Abstand zwischen Wiederholungen
          description: Nur bei "Gleichmäßig durchlaufend" sichtbar.
          default: 8
          selector:
            number:
              min: 0
              max: 64
              unit_of_measurement: px
              mode: box
        scroll_hold_ms:
          name: Pause vor dem Start
          description: Gilt auch an jedem Wendepunkt beim Hin-und-her-Pendeln.
          default: 1000
          selector:
            number:
              min: 0
              max: 5000
              step: 100
              unit_of_measurement: ms
              mode: box
    farben:
      icon: mdi:palette-swatch
      input:
        text_color:
          description: Gilt immer, außer ein Schwellenwert unten greift oder "Regenbogen-Effekt" (bei Effekte & Overlay) ist aktiv.
          default: [255, 255, 255]
          selector:
            color_rgb: {}
        use_thresholds:
          name: Farbe nach Schwellenwert wechseln
          description: Ersetzt die Standardfarbe automatisch, sobald der Sensorwert eine der beiden Schwellen unten erreicht - z. B. grün/orange/rot je nach Temperatur.
          default: false
          selector:
            boolean: {}
        threshold_low:
          description: Ab diesem Wert (und darunter) gilt "Farbe niedrig".
          default: 0
          selector:
            number:
              min: -1000
              max: 1000
              mode: box
        color_low:
          default: [80, 170, 255]
          selector:
            color_rgb: {}
        threshold_high:
          description: Ab diesem Wert (und darüber) gilt "Farbe hoch".
          default: 100
          selector:
            number:
              min: -1000
              max: 1000
              mode: box
        color_high:
          default: [255, 60, 60]
          selector:
            color_rgb: {}
    effekte:
      name: Effekte & Overlay
      icon: mdi:auto-fix
      collapsed: true
      input:
        effect_id:
          description: >-
            Animierter Ambiente-Hintergrund, solange diese App zu sehen ist.
            Nicht zu verwechseln mit dem Übergang zwischen Apps (siehe ganz
            unten bei "Geräteweite Einstellungen") - das ist etwas anderes.
            Diese Liste ist ein bestes Best-Effort; sollte ein Name auf
            deiner Firmware nicht existieren, sag Bescheid.
          default: ""
          selector:
            select:
              mode: dropdown
              options:
                - value: ""
                  label: "Kein Effekt"
                - value: "Plasma"
                  label: "Plasma"
                - value: "PlasmaCloud"
                  label: "PlasmaCloud"
                - value: "Matrix"
                  label: "Matrix"
                - value: "Fireworks"
                  label: "Fireworks"
                - value: "Ripple"
                  label: "Ripple"
                - value: "Radar"
                  label: "Radar"
                - value: "Snake"
                  label: "Snake"
                - value: "PingPong"
                  label: "PingPong"
                - value: "BrickBreaker"
                  label: "BrickBreaker"
                - value: "Checkerboard"
                  label: "Checkerboard"
                - value: "ColorWaves"
                  label: "ColorWaves"
                - value: "LookingEyes"
                  label: "LookingEyes"
                - value: "MovingLine"
                  label: "MovingLine"
                - value: "Pacifica"
                  label: "Pacifica"
                - value: "SwirlIn"
                  label: "SwirlIn"
                - value: "SwirlOut"
                  label: "SwirlOut"
                - value: "TheaterChase"
                  label: "TheaterChase"
                - value: "TwinklingStars"
                  label: "TwinklingStars"
        rainbow:
          name: Regenbogen-Effekt für den Text
          description: Überschreibt Standard- und Schwellenwertfarben mit einem animierten Farbverlauf.
          default: false
          selector:
            boolean: {}
        effect_speed:
          name: Tempo (Effekt & Overlay)
          description: Gilt für Hintergrundeffekt UND Wetter-Overlay gemeinsam. 1.0 = normal.
          default: 1.0
          selector:
            number:
              min: 0.1
              max: 10.0
              step: 0.1
              mode: slider
        overlay:
          description: Animierte Auflage über die gesamte Anzeige - z. B. praktisch bei einem Temperatur- oder Wettersensor.
          default: ""
          selector:
            select:
              mode: dropdown
              options:
                - value: ""
                  label: "Kein Overlay (Geräte-Standard)"
                - value: "rain"
                  label: "Regen"
                - value: "snow"
                  label: "Schnee"
                - value: "drizzle"
                  label: "Nieselregen"
                - value: "storm"
                  label: "Sturm"
                - value: "thunder"
                  label: "Gewitter"
                - value: "frost"
                  label: "Frost"
    balken:
      name: Balken & Ablaufzeit
      icon: mdi:progress-clock
      collapsed: true
      input:
        show_progress:
          description: Praktisch für Prozentwerte, z. B. Luftfeuchte, Akkustand oder Druckfortschritt.
          default: false
          selector:
            boolean: {}
        progress_min:
          name: Balken entspricht diesem Wert bei 0 %
          default: 0
          selector:
            number:
              min: -1000
              max: 1000
              mode: box
        progress_max:
          name: Balken entspricht diesem Wert bei 100 %
          default: 100
          selector:
            number:
              min: -1000
              max: 1000
              mode: box
        lifetime_min:
          description: Liefert der Sensor so lange keinen neuen Wert, verschwindet die App vom Panel. 0 = nie ausblenden.
          default: 30
          selector:
            number:
              min: 0
              max: 1440
              unit_of_measurement: min
              mode: box
    geraeteeinstellungen:
      name: Geräteweite Einstellungen
      icon: mdi:cog-outline
      collapsed: true
      input:
        apply_device_settings:
          name: Übergang zwischen Apps mitsetzen
          description: >-
            Ändert bei jeder Aktualisierung zusätzlich, wie das Panel
            zwischen Apps wechselt - wirkt sich auf ALLE Apps auf dem Panel
            aus, nicht nur auf diese eine. Standardmäßig aus, damit diese
            Automation nichts Geräteweites verändert, ohne dass du es willst.
          default: false
          selector:
            boolean: {}
        transition_effect:
          description: Nur wirksam, wenn oben aktiviert.
          default: "Random"
          selector:
            select:
              mode: dropdown
              options:
                - "Random"
                - "Slide"
                - "Dim"
                - "Zoom"
                - "Rotate"
                - "Pixelate"
                - "Curtain"
                - "Ripple"
                - "Blink"
                - "Reload"
                - "Fade"
                - "Cover"
                - "Uncover"
                - "Split"
                - "Blinds"
                - "Blocks"
                - "Flash"
                - "Diamond"
                - "Wave"
                - "Rain"
                - "Melt"
                - "Interlace"
mode: single
max_exceeded: silent
variables:
  unit: !input unit
  icon_id: !input icon_id
  text_color: !input text_color
  center: !input center
  text_case: !input text_case
  duration_sec: !input duration_sec
  scroll_mode: !input scroll_mode
  scroll_speed: !input scroll_speed
  scroll_direction: !input scroll_direction
  scroll_entry: !input scroll_entry
  scroll_when_fits: !input scroll_when_fits
  scroll_gap: !input scroll_gap
  scroll_hold_ms: !input scroll_hold_ms
  effect_id: !input effect_id
  effect_speed: !input effect_speed
  overlay: !input overlay
  rainbow: !input rainbow
  show_progress: !input show_progress
  progress_min: !input progress_min
  progress_max: !input progress_max
  lifetime_min: !input lifetime_min
  use_thresholds: !input use_thresholds
  threshold_low: !input threshold_low
  color_low: !input color_low
  threshold_high: !input threshold_high
  color_high: !input color_high
  app_name: !input app_name
  awtrix_device: !input awtrix_device
  apply_device_settings: !input apply_device_settings
  transition_effect: !input transition_effect
  # Liest den MQTT-Prefix live von der eigenen "MQTT prefix"-Sensor-Entität
  # des gewählten AWTRIX-Geräts aus - passt sich automatisch an, falls du das
  # Panel jemals umbenennst oder neu einrichtest.
  mqtt_topic: >-
    {% set prefix_entity = device_entities(awtrix_device) | select('match', '^sensor\..*_mqtt_prefix$') | list | first %}
    {{ states(prefix_entity) if prefix_entity else 'awtrix' }}
triggers:
  - trigger: state
    entity_id: !input sensor_entity
conditions:
  - condition: not
    conditions:
      - condition: state
        state: ["unknown", "unavailable", "none"]
actions:
  - action: mqtt.publish
      topic: "{{ mqtt_topic }}/cmd/apps/pushed/{{ app_name }}"
      payload: >-
        {% set payload = {
          'text': trigger.to_state.state ~ unit,
          'textCenter': center,
          'textCase': text_case,
          'scroll': {
            'mode': scroll_mode,
            'speed': scroll_speed | int(100),
            'direction': scroll_direction,
            'entry': scroll_entry,
            'whenFits': scroll_when_fits,
            'gap': scroll_gap | int(8),
            'holdMs': scroll_hold_ms | int(1000)
          'effect': effect_id,
          'effectSpeed': effect_speed | float(1.0),
          'overlay': overlay,
          'lifetimeMs': (lifetime_min | int(0)) * 60000,
          'lifetimeExpiry': 'remove'
        {% if icon_id %}
          {% set payload = dict(payload, icon=icon_id) %}
        {% endif %}
        {% set value = trigger.to_state.state | float(0) %}
        {% if use_thresholds and value <= (threshold_low | float(0)) %}
          {% set active_color = color_low %}
        {% elif use_thresholds and value >= (threshold_high | float(100)) %}
          {% set active_color = color_high %}
        {% else %}
          {% set active_color = text_color %}
        {% endif %}
        {% if rainbow %}
          {% set payload = dict(payload, palette='Rainbow', textColor='palette') %}
        {% else %}
          {% set payload = dict(payload, textColor=[active_color[0] | int, active_color[1] | int, active_color[2] | int]) %}
        {% endif %}
        {% if duration_sec | int(0) > 0 %}
          {% set payload = dict(payload, durationMs=(duration_sec | int(0)) * 1000) %}
        {% endif %}
        {% if show_progress %}
          {% set span = (progress_max | float(100)) - (progress_min | float(0)) %}
          {% set raw_pct = ((value - (progress_min | float(0))) / span * 100) | round(0) | int if span != 0 else 0 %}
          {% set pct = 0 if raw_pct < 0 else (100 if raw_pct > 100 else raw_pct) %}
          {% set payload = dict(payload, progress=pct, progressColor=[active_color[0] | int, active_color[1] | int, active_color[2] | int]) %}
        {% endif %}
        {{ payload | tojson }}
  - if:
      - "{{ apply_device_settings }}"
    then:
          topic: "{{ mqtt_topic }}/cmd/settings"
          payload: >-
            {{ {'transitionEffect': transition_effect} | tojson }}
created with Claude
