Back out of duckdns ssl - help!
I tried to install this, setup duckdns, port forwarding on my router and configured addin and config files. Got it running but was going slower than molasses, taking 3 or 4 minutes to just load the login screen. So I decided to back out so that I could do some more research before attempting again so I uninstalled the duckdns adding, commented out the changes to the configuration.yaml. I am back up and running but many apps not do not run. From supervisor, if I openwebui for file editor, I just get a black screen. If try to open it from the sidebar I get a 401: unauthorized error. This is the second time around that this has failed for me, the first time I just wrote off my install and went back to scratch. This time before I started, i took a snapshot before I did anything, everything was working fine. So I tried restoring my snapshot and nadda which leads me to believe the snapshot does not 100% restore you to your previous state? Is my issue with the ssl certificates that were created when I installed duckdns?
I think I resolved this myself. Cleared browsing history, rebooted my workstation, reset my router and rebooted my Qnap NAS running the VM. This SSL crap is not for the faint of heart. still not sure why I can’t get duckdns to work properly…
