I have 2 places for backup: system (used 7.9%) and USB-Stick (and Nabucasa)
If I start automatic backup an error appears: could not be stored on USB-Stick:
Logger: homeassistant.components.backup
Quelle: components/backup/manager.py:1056
Integration: Backup (Dokumentation, Probleme)
Erstmals aufgetreten: 12. März 2025 um 23:40:35 (10 Vorkommnisse)
Zuletzt protokolliert: 07:57:21
Backup agents [‘home assistant OS.usb_backup’] are not available, will backupp to [‘home assistant OS.local’, ‘cloud.cloud’]
It is stored on system and in cloud - but not on USB-Stick.
If I use manual backup with custom backup and select all spaces
it works.
If I use manual backup with predefined places the backup error comes up again.
It was working until ca. 4 weeks ago. Now I found out that the USB port of the fritzBox on the side does not work (the USB_stick was really hot all the time). So I changed to the second USB of the Firitzbox. Now the stick is recognized.and I can see it in FritzNas and read the content.
I use the same configuration (USB on a Fritzbox) on my second HA-installation in another house without error.
What could be the reason that the automatic backup does not like the USB-Stick? Has the USB-Port in Fritz!Box any influence? Then why is working in custom-Mode?
Thanks for ideas
- Core2025.3.1
- Supervisor2025.03.2
- Operating System14.2
- Frontend20250306.0
