Backup restore does not work
I have a backup made in a docker container running Home Assistant 2022.12.8
Now I want to restore this backup into version 2025.4.2-ls96
I’ve created a user, then opened the backup menu, uploaded my backup and now I want to restore it but HA hallucinates that it is encrypted and demands a key. There is no key, it is not encrypted.
Tried to install the old version so I can restore into the same version. Unfortunately there is no restore button in Home Assistant 22.12.8.
During setup there is also no restore function.
Why oh why is there a backup function if restoring is not even a feature.
Backups work for 99% of cases. To say there is no restore button is just wrong.
Read this.
and this
Links to unrelated topics regarding other versions of HA are not helpful. You may want to read the message in stead of only the title.
You can open the backup using 7zip, and manually copy the contents to your /config directory.
thanks I will try this
