plord
(Peter Lord)
February 21, 2025, 8:41pm
1
I noticed Common tasks - installation independent - Home Assistant mentions that the config directory is backed up … this doesn’t seem to be the case.
For example I have /config/openhasp/ directory (to support openhasp) and this isn’t included in the backup.
To test the backup I -
Trigged an automated backup
Downloaded the tar file
Used borgify-ha-backup.py to decrypt to x.tar
tar -xvf x.tar
tar -xvf homeassistant.tar
The extracted data directory contained only some files for the original config directory.
Sir_Goodenough
((SG) WhatAreWeFixing.Today)
February 22, 2025, 2:47am
2
I suggest changing the category to Feature Requests - Home Assistant Community and adjusting the text to fit a request to make this happen.
I was under the impression that subfolders were pulled into the backup. If what you say is true, so I would vote for this if you made your changes. @plord
plord
(Peter Lord)
February 22, 2025, 9:00am
3
Huh.
I’ve just updated to todays release, turned off encryption (hard to validate backups with encryption turned on) and now it seems to be working.
$ tar -tvzf homeassistant.tar.gz | grep openhasp
drwxr-xr-x 0 root root 0 17 Feb 22:06 data/openhasp/
-rw-r--r-- 0 root root 18001 21 Feb 16:35 data/openhasp/pages.jsonl
I don’t know if this was fixed or if encryption triggers the issue.
I noticed some bug reports about the files excluded from backups (core/homeassistant/components/backup/const.py at 3160b7baa0545b04cda68ee77ebe91b50c6ca0b0 · home-assistant/core · GitHub ) but that doesn’t seem to be the cause here.
