I have set up an ESP8285 IR transceiver with ESPHome and it all works fine except for when I try to click Visit in ESPHome Builder or try to visit the device IP in a web browser. When this failure happens, the device log shows:
[17:30:32.657][D][api:136]: Accept 192.168.1.85
[17:30:32.672][VV][api.noise:162]: 192.168.1.85 (192.168.1.85): Bad indicator byte 71
[17:30:32.672][W][api.connection:1978]: 192.168.1.85 (192.168.1.85): Socket operation failed BAD_INDICATOR errno=11
[17:30:32.690][V][api:193]: Remove connection 192.168.1.85
My question is: Should I be able to get a web interface for this device?
Yaml for the device:
esphome:
friendly_name: "ir-remote-1"
esp8266:
board: esp01_1m
# Enable logging
logger:
level: VERY_VERBOSE
# Enable Home Assistant API
api:
encryption:
key: !secret esphome_encryption_key
ota:
- platform: esphome
password: "xxxxxxxxxxxxxxxxxxxxxx"
web_server:
port: 80
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Irremote1 Fallback Hotspot"
password: "xxxxxxxxxxxxxxx"
captive_portal:
remote_receiver:
pin:
number: GPIO14
inverted: true
dump: all
remote_transmitter:
pin:
number: GPIO4
carrier_duty_percent: 50%
button:
on_press:
- remote_transmitter.transmit_sony:
data: 0x00000A90
nbits: 12
