Hi all.
I’m new here, discovering Home Assistant.
I had some previous experiences with OpenHAB, but it seems to me HA has some…gear more (bad transposition from italian…I mean: something more).
Unfortunately, I’m not starting in the best way…
I got my Raspi 4 (4Gb), downloaded and and installed HA (following all the instructions).
Currently I’m running it on a dedicated LAN (just for test - no internet); I can see HA in my clients list (with IP 192.168.1.101), but no way to access it…
I tried all the possibilities:
homeassistant.local:8123
homeassistant:8123
192.168.1.101:8123
But nothing to do.
I tried even with SSH access (Putty), but no way
I installed the 64bit vers, but as the Pi4 has only 4 Gb, I tried with the 32bit vers.
Both cases, no way to access it.
Yes, though Home Assistant OS will require some changes to allow it still to function (I don’t run it, I don’t know exactly what they are, but they’ll be around DNS and NTP).
Of course, no cloud integration will work, you won’t be able to send notifications, and you won’t be able to update…
I don’t have any experience with “supervised” installations like HA OS oder HA Supervised. Of course you require temporary internet access when installing any Home Assistant flavour, but since the underlying OS provides date/time and everything is downloaded when not using supervisior - it should run without internet.
