I have a badge that shows me a count of all lights that are On. And I have a card that shows me a list of the lights that are On. I would like to when I tap the badge, I have a popup with the card that lists all the lights that are On. Is that possible?
Thank you.
It’s been asked for. Let’s hope it gets implemented.
https://community.home-assistant.io/t/wth-cant-we-have-a-true-popup-card/805534/6
if you have some experience with yaml mode, you can create your own popup with your current light card
I don’t know if this is a Feature request or not. You should search for it in the frontend Feature Request page and if it’s not one, add it.
Please add your Feature Request into GitHub here:
home-assistant/frontend Other Feature Requests · Discussions · GitHub.
Thanks guys for the info. I thoght it would’ve been something that existed already
I played around with the Popup feature of Card-Mod and found it to be sketchy at best. Sometimes it would not popup on mobile devices and sometimes it just wouldn’t work at all. Eventually I just deleted card-mod as this was the only reason I installed it.
It would seem that a built in card would be pretty easy to create, since its just a derivative of the more-info popup with the ability add custom text, buttons or entities.
What is a “Popup feature of Card-Mod”?
There is no such a feature.
Perhaps you tried to use card-mod with some popup.
My bad, Browser-Mod
