Not sure where it came from or what it is.
Home Assistant shows it as a discovered device, but I have no idea where in the house it is, or even what it is.
It shows that it’s a homekit controller…
Any ideas how to tell what this thing is or any info about it???
Apple TV.
Home pod / mini.
iPad set up as a home hub.
Neighbour’s device?
The HomeKit hub that HA automatically creates for you when you do a new install???
It does not do that unless you have one.
It may use the Home Connect integration if you have any devices that can connect via that method.
I have no Apple stuff in the house and this is a new installation.
I have a Verizon Smart TV, a wireless garage door opener an Arlo camera station and my Xfinity gateway .
Nothing has this number listed anywhere.
Is there a catalog anywhere that might have anything listed???
i have the same issue
unknown homekit controller discovered
i have zero apple product
it will be really helpful if it tells me the IP or mac address
It is not only Apple devices that use the Homekit protocol.
so i need to know the IP
