-bash: hass: command not found
Hello, when I run
hass --script check_config
I receive the following error:
Can you help?
Thank you.
Depending on the installation method you performed you need to activate the venv or use the full path to hass.
Thank you for your reply. I used Raspberry Pi All-in-One instructions.
I tried to run full path, but:
pi@Home-Assistant:~ $ /srv/homeassistant/homeassistant_venv/bin/hass --script check_config
Config does not exist: /home/pi/.homeassistant/configuration.yaml
And this is correct, Configuration file exists in /home/homeassistant/.homeassistant folder.
