Basic questions re: network configuration
Hello all. Completely new to HA. I am one of the many who are moving from Wink.
Anyway, as I prepare for Amazon to hopefully deliver my hardware, I already have (most likely dumb) questions. I’ve followed the instructions to create the USB config drive. I would like to set a static IP to the device.
I went to the website and wanted to know …
(1) Do you create a text file and call it “network.md” and then copy and paste the code in? If not, then what do I do?
(2) Do I need this code as the default code? What is the ID/UUID? Is that something standard or do I get that from my router or something?
[connection]
id=my-network
uuid=d55162b4-6152-4310-9312-8f4c54d86afa
type=802-3-ethernet
[ipv4]
method=auto
[ipv6]
addr-gen-mode=stable-privacy
method=auto
(3) If I don’t need the above code, is this sufficient enough, once I edit with my IP info?
[ipv4]
method=manual
address=192.168.1.111/24;192.168.1.1
dns=8.8.8.8;8.8.4.4;
