Basic Timer with Adjustable Time Setting
The wife wanted a way to switch on the slow cooker at a set time, our slow cooker doesnt have a timer built in so using a Sonoff switch i have created a really basic timer so we can switch the slow cooker on at an adjustable time.
The timer consists of an Input Select with a list of times, an input boolean for enabling the timer and the automation requires the time sensor (although i think you can do this without that sensor but it easier with it)
Input_Select:
switch_1_timer_select:
  name: Timer Start Time
  options:
    - '08:00'
    - '08:30'
    - '09:00'
    - '09:30'
    - '10:00'
    - '10:30'
    - '11:00'
    - '11:30'
    - '12:00'
    - '12:30'
    - '13:00'
    - '13:30'
    - '14:00'
    - '14:30'
    - '15:00'
    - '15:30'
  icon: mdi:timer
Input_Boolean:
switch_1_timer_input:
  icon: mdi:clock-start
Automation:
- alias: 'Timer Switch 1 On'
  initial_state: true
    - platform: time
      minutes: '/1'
      seconds: '0'
  condition:
    - condition: and
      conditions:
        - condition: state
          entity_id: input_boolean.switch_1_timer_input
          state: 'on'
        - condition: template
          value_template: '{{ states.input_select.switch_1_timer_select.state == states.sensor.time.state }}'
    - service: switch.turn_on
      entity_id: switch.sonoff_power_1
    - service: notify.ios_iPhone
        message: 'Sonoff Switch 1 has been switched on based on the timer.'
    - service: input_boolean.turn_off
The automation runs every minute and compares the current time against the time in the input select. If they match and the input_boolean has been enabled the automation triggers switching on the Sonoff, sending an alert to my phone and then switches off the input boolean so it doesnt run again.
Like i said, its basic but might be useful for someone else.
This sounds like a recipe for food poisoning.
