🚿 Bathroom Humidity Exhaust Fan
New update 2.1
New Features :new:
  • Manual Fan Switch Option - This allows you to add a switch to turn the fan ON and OFF manually and still allows the automation to be triggered, taking control of your fan :partying_face:. This is useful in removing any unwanted fumes from deodorant, hairspray, toilet etc. The auto off time delay in option 2 makes sure you never forget to turn the fan OFF.
    The switch can be:
    • Switch
    • Binary sensor
    • Input boolean
:warning: Please Note: The switch can not be the actual fan switch and must be independent. If you use the actual fan switch then the automation will not work.
What can this now do?
  1. If you have a toilet in the bathroom you can now have a physical manual switch on the wall, or a sensor that can turn the fan on for a set time period. If you then have a shower the automation will take control of your fan.
  2. Getting ready for the day and you spray deodorant or hairspray and would like to remove the fumes?.. you can now turn the fan ON and OFF or use the auto OFF option and it will run for X amount of time.
  3. Getting in the shower and you would just like to start the fan manually from the start and not wait for the trigger to then have the automation take control, this is now possible.
  4. Turn the fan ON and OFF in HA or with a local switch + opt to use a time delay option, this is now possible.
  5. Cancel the automation with a local fan switch or in HA dashboard, turn the switch ON and OFF. It may restart depending on site conditions.
It can do more but I think you get the idea.
If you like this blueprint? Consider hitting the :heart: button in the top post :+1:
If you like my blueprints, and would like to show your support or just say thank you? Click Here :smiling_face_with_three_hearts:
Enjoy
Blacky :grinning:
