I have a battery that is connected to mains power through a power point into the mains like any other power point in a building. It has other power points out to other devices that consumes the power that is stored in the battery. The battery charges up at night when the power is a lower price and is discharged during the day.
The battery has a TPLink Tapo connected to it to monitor the power usage that it uses from the wall, and the devices each have a separate power monitor (same brand) connected to monitor their usage.
I want to monitor the devices’ usage in the Energy dashboard and use the battery in/out monitor to work out how much is being discharged and create the Energy’s graph and display the correct values.
I’ve tried using the Sum Devices for the devices connected to the battery’s outflow side and it gives me an error as all the properties are not there:
As, so far, no one has created a HACS plugin for the Ecoflow Delta Plus 3, this is the only workaround that I’ve got. I still have no way of monitoring it’s solar panels yet, but can fudge together this.
How can I add the values of the sensors so that the battery outflow is received correctly by HA?
