I have been experimenting with combining multiple temperature sensors in Home Assistant for a while, and it eventually grew into a separate custom integration:
Bayesian State Filter
GitHub: GitHub - pterodaktil02/bayesian_state_filter: Bayesian State Filter for Home Assistant · GitHub
One important clarification first: this is not an alternative implementation of Home Assistant’s built-in bayesian integration.
The built-in bayesian integration estimates the probability of an event and produces a binary_sensor.
bayesian_state_filter, on the other hand, is intended for numeric sensors and continuous-valued quantities. For example, if you have several temperature sensors in the same room, it produces a single estimate of the shared latent “true” room state.
Conceptually:
sensor 1 ─┐
sensor 2 ─┼─> Bayesian State Filter ─> fused numeric sensor
sensor 3 ─┤
sensor 4 ─┘
The filter accounts for different sensor offsets, different effective noise levels, different update rates, and asynchronous measurements.
One of the main reasons I built it was outlier handling and sensors that temporarily drift away from the rest of the ensemble. State updates use Student-t weighting: a strongly inconsistent observation is not simply discarded, but its influence is automatically reduced.
Each source gets its own relative bias and effective sigma. Source uncertainty is calibrated from close-in-time pairs of measurements:
Var(sensor_i - sensor_j) ≈ sigma_i² + sigma_j²
This helps separate actual process dynamics from source-specific observation noise.
At startup, the integration can use Home Assistant Recorder history for initial calibration and pretraining. It also estimates a characteristic time scale of the observed process using a robust temporal semivariogram.
The current version supports both Gaussian and Poisson-family observation models. The latter is useful for count-based sensors. Automatic Gaussian/Poisson detection is not implemented yet: in version 0.2.1.6, noise_model: auto intentionally defaults to Gaussian.
Example configuration:
- platform: bayesian_state_filter
name: "Room temperature"
ensemble:
sources:
- sensor.temperature_1
- sensor.temperature_2
- sensor.temperature_3
- sensor.temperature_4
min_sources: 2
bayes:
noise_model: auto
history_days: 7
save_every_s: 60
student_nu: 4
diagnostics: compact
The resulting entity exposes diagnostics both for the overall filter and for each individual source, including bias, sigma, innovation, z_score, robust weight, outlier counters, and the most recent per-source update diagnostics.
The component is already being used and tested on a real Home Assistant installation. The repository also includes regression tests, including synthetic source-calibration tests and characteristic-time estimation tests.
Current version: 0.2.1.6
Configuration is YAML-only for now. Config Flow, broader Home Assistant integration tests, and automatic Poisson/Gaussian model detection are planned for later versions.
License: GPL-3.0.
Feedback is very welcome, especially real datasets where the filter behaves strangely. For this kind of estimator, one bad real-world example is often more useful than ten beautiful synthetic tests.
