Bcm2711-rpi-cm4-ha-yellow.dtb
scp .\bcm2711-rpi-cm4-ha-yellow.dtb user@yourdeviceIP:/home/youruser
scp .\overlays\rpivid-v4l2.dtbo user@yourdeviceIP:/home/youruser
I was using the default rpi lite 64bit image instead of the HAOS
I found cat/sys/class/thermal/thermal_ Zone 0/temp is invalid
Can provide the code for bcm2711-rpi-cm4-ha-yellow.dtb?
My Home Assistant Yellow is using the official system of Raspberry Pi. Yellow’s i2c interface is i2c6, and RTC is configured to i2c6 by default
Are you trying to install the official HAOS for Yellow, or?
How to reinstall the operating system – Home Assistant Yellow (home-assistant.io)
Anyway, the sources are at
GitHub - NabuCasa/yellow-buildroot: Buildroot for Yellow Installer and Tester
