Beautiful Room Card
Hi!
I just want to share with you my last Room Card template. To create the card, you need to install Mushroom Cards, Card-mod, Stack in card, and ApexCharts Card through HACS.
You can get full code and guide in my blog. Since is one of the ‘most like’ among my crads, i wrote the guide both in english and spanish.
Hope you like it!
Hello @TiToTB, all,
This is really beautifull card. I tried to use it but I am expiriencing problems with alignement.
Displaying in computer browser looks like that:
after F5 it look like this:
On my Samsung phone it is much better but still not as good as You have it.
Is it possible to fix this behaviour?
Yan
Hi!
As far as i know, if you have many cards in the same panel, it will load slower and It may cause this issues. Also if you have Home Assistant in less powerful hardware like a RPi 3 or so.
If It sounds familiar, try to move some of your cards to other panels.
Regarding alignment, you can fix It using ‘margin left’, but i guess you already know this.
I hope It helps
I’ve found adjusting the browser zoom will cause the temp dial to offset. Maybe try adjusting browser zoom to see if that works for you.
Wow! This cards are absolutely beautiful! Thank you so much for sharing!
Is there a way to make the text in the header bigger? I tried almost everything with card-mod without success… :cry:
and could you tell me, how you make the washing machine shake, I really love that! :blush:
One thing I want to mention for others who want to use your cards: after the last update of mushroom cards, one should use
custom:mushroom-legacy-template-card
instead of
custom:mushroom-template-card
in order to get the old functionality we are used to and your instructions expect.
Thanks!
I haven’t played yet with the new version of mushoroom template and card mod.
Have you tried this?
–card-primary-font-size: 20px;
I use the mushroom-legacy-template-card.
–card-primary-font-size did not work
But I found a solution meanwhile:
   card_mod:
      style:
        mushroom-state-info$: |
          .container .primary {
            font-size: 20px !important;
            font-weight: 600 !important;
            font-variant: small-caps;
          .container .secondary {
            font-size: 16px !important;
Hi first of all beautiful cards. I’m trying to use your cards with the following code:
type: custom:stack-in-card
card_mod:
  style: |
    ha-card {
      background: linear-gradient(rgba(0,0,0,0.7), rgba(0,0,0,0.7)), url('/local/habitaciones/dormitorio.jpg');
      background-position: center;
      background-size: cover;
      --primary-text-color: #ffffff;
      min-height: 133px;
cards:
  - type: custom:mushroom-legacy-template-card
    primary: Living Room
    icon: mdi:sofa
    card_mod:
      style: |
        ha-card {
          border: 0px;
    tap_action:
      action: none
    layout: horizontal
    primary: ""
    secondary: ""
    icon: mdi:bed
    icon_color: teal
    tap_action:
      action: none
    card_mod:
      style: |
        ha-card {
          border: 0px;
          --icon-size: 100px;
          margin-left: -25px;
          margin-bottom: -55px;
          margin-top: -32px;
        mushroom-badge-icon {
          margin-right: 10px;
          margin-top: 10px;
          --badge-icon-size: 10px;
          --badge-size: 20px;
    badge_icon: >
      {% if (states('sensor.sensor_temperatura_dormitorio_humidity') | int) >=
      60 %} mdi:water {% elif
      (states('sensor.sensor_temperatura_dormitorio_temperature') | int) >= 26
      %} mdi:fire {% elif
      (states('sensor.sensor_temperatura_dormitorio_temperature') | int) <= 18
      %} mdi:snowflake {% endif %}
    badge_color: >
      60 %} blue
      {% elif (states('sensor.sensor_temperatura_dormitorio_temperature') | int)
      >= 26 %} red
      <= 18 %} blue
      {% endif %}
  - type: custom:stack-in-card
    card_mod:
      style: |
        ha-card {
          background: transparent!important;
          margin-top: -110px;
          margin-left: auto;
          margin-right: 5px;
          width: 44%;
          border: 0px;
    cards:
      - type: grid
        square: false
        columns: 1
        cards:
            primary: ""
            secondary: ""
            layout: vertical
            icon: mdi:ceiling-light
            entity: switch.living_room_li
            icon_color: >
              {% if (states('light.bombilla_dormitorio')) == 'on' %} teal {%
              endif %}
            card_mod:
              style: |
                ha-card {
                  border: 0px;
                  --icon-size: 35px;
                  margin: -10px!important;
            primary: ""
            secondary: ""
            layout: vertical
            icon: mdi:lightbulb-variant-outline
            entity: light.bombilla_dormitorio_filamento
            icon_color: >
              {% if (states('light.bombilla_dormitorio_filamento')) == 'on' %}
              teal {% endif %}
            card_mod:
              style: |
                ha-card {
                  border: 0px;
                  --icon-size: 35px;
            primary: ""
            secondary: ""
            layout: vertical
            icon: mdi:television
            entity: media_player.box
            tap_action:
              action: more-info
            icon_color: >
              {% if (states('media_player.tv_dormitorio')) == 'off' %} {% else
              %} teal {% endif %}
            card_mod:
              style: |
                ha-card {
                  border: 0px;
                  --icon-size: 35px;
However I’m getting an unformmatted card like this:
Any idea of what am I missing?
Thanks!
Have you install all required cards?
I thought it was just a GIF at first, but it’s actually possible to recreate it with a small CSS animation.
I did need some help from ChatGPT to figure this one out.
In my case this works by adding the following to the card_mod: section of the washing machine card.
Important detail: for me it only worked on ha-state-icon.
card_mod:
  style: |
    ha-card {
      border: 0px;
      --icon-size: 35px;
    @keyframes washer-shake {
      0%   { transform: rotate(0deg) scale(1); }
      10%  { transform: rotate(-6deg) scale(1.04); }
      20%  { transform: rotate(5deg) scale(1); }
      30%  { transform: rotate(-8deg) scale(1.04); }
      40%  { transform: rotate(6deg) scale(1); }
      50%  { transform: rotate(-4deg) scale(1.02); }
      60%  { transform: rotate(3deg) scale(1); }
      70%  { transform: rotate(-2deg) scale(1.02); }
      80%  { transform: rotate(2deg) scale(1); }
      100% { transform: rotate(0deg) scale(1.04); }
    ha-state-icon {
      {% set s = states('sensor.wasmachine_machinestatus') %}
      {% if s == 'run' %}
        animation: washer-shake 0.8s ease-in-out infinite;
        transform-origin: center;
      {% endif %}
You can tweak it a bit depending on the effect you want:
  • increase/decrease the rotation values for more or less movement
  • adjust the scale (1.01–1.04 range works well)
  • change the duration (e.g. 0.6s faster, 1s slower)
  • avoid perfectly symmetrical values, it looks more natural this way
