Beep and Haptic Feedback in Home Assistant
I am using the manual alarm panel in a HA dashboard. I have touch sounds and haptic feedback turned on in my Android settings which works in most other Android areas but as soon as I use HA I get no sound. I particularly want to use it when people enter the alarm code on the dashboard keypad. Anyone know if this is possible? Thanks
Did you ever find a solution for this? I’m trying to do the same, but I hate how the keypad doesn’t feel “responsive”
Looking at the docs it sounds as if haptics may not have been added for keypads.
However, they may have been disabled in your profile settings, so you should check that.
If you are using a custom keypad like Alarmo you need to contact the developer to request the feature.
