I have a panel of chargers hooked up to blind motors.
I checked the ‘idle’ power usage, those little guys use a bit each, so…
The panel is now on a ZigBee smart switch that requires a bit of scripting to give it the full scrooge McDuck effect.
Is the scripting logic able to do something like…
On any third Saturday of the month turn the ZigBee switch on between 0100 to 0430
OR
If on any day between (sunset + 10 minutes) and (sunset + 15 minutes) if blind position for ‘Blind1’ or ‘Blind2’… is not 100% (Down) turn the ZigBee switch on for 3 hours, position all blinds to 100% and log out of normal hours activity.
If the the scripting is as limited as most then its not worth installing the server.
If yes then were is the best resource to read up on the logic?
Thanks, Kevi.
