Beginner: configuration.yaml error while parsing a block mapping
I’m installed a Home Assistant current a vew days ago and I want to include a template in configuration.yaml.
When I check in in HA UI I got the error:
Error loading /config/configuration.yaml: while parsing a block mapping
in “/config/configuration.yaml”, line 2, column 1
expected , but found ‘}’
in “/config/configuration.yaml”, line 50, column 2
I have tried serveral failures I read in your community, but the failure is still here. I don’t know where it is.
I
My Configuration.yaml.:
# Loads default set of integrations. Do not remove.
default_config:
# Load frontend themes from the themes folder
frontend:
  themes: !include_dir_merge_named themes
script: !include scripts.yaml
scene: !include scenes.yaml
template:
  - sensor:
      - name: "Energy Total"
        unique_id: energy_total
        state: >-
            [ states( 'sensor.shellyem3-3494547B6D80_cannel_a_energy'),
              states( 'sensor.shellyem3-3494547B6D80_cannel_b_energy'),
              states( 'sensor.shellyem3-3494547B6D80_cannel_c_energy'),
            ] | map('float') | sum
        availability: >-
            ] | map('s_number') | min
        unit_of_measumnt: kWh
        device_class: energy
        state_class: total_increasing
      - name: "Power Total"
        unique_id: power_total
        state: >-
        unit_of_measurement: W
        device_class: power
        state_class: measurement
        availability: >
          {{ not 'unavailble' in
             [ states( 'sensor.shellyem3-3494547B6D80_cannel_a_power'),
               states( 'sensor.shellyem3-3494547B6D80_cannel_b_power'),
               states( 'sensor.shellyem3-3494547B6D80_cannel_c_power') ]
What is wrong?
Best regards
Sislfitz
Is the last one in the wrong place ?
Also unavailable is spelt wrong
And I think you’ve used the energy entities instead of power ones ?
default_config:
frontend:
template:
  - sensor:
        state: >-
        availability: >-
        state: >-
              states( 'sensor.shellyem3-3494547B6D80_cannel_c_power'),
        device_class: power
        availability: >
          {{ not 'unavailable' in
So, you actually don’t need a template for any of these calculations, just use the sensor group helper with ‘sum’ as the math calc. All done via the UI, and it’ll handle all this junk for you.
Hi Petro,
where can I find “Sensor Group Helper”? I’m brand new in Home Assistant.
THANKS!!!
Settings → Devices & Services → Helpers (tab) → + Create Helper (button) → Group
Hi Petro,
I found it and I configured it! Great!!!
On the other side: YAML is a very ridiculus tool. The error messages of a compiler are nicer. The syntax check of YAML is like an old tool. Tab are not allowed… and so on.
But help here is very good!!!
Best regards,
Sislfitz
Hi Holdestmade,
Thank you for your inputs. I was successful making my YAML config running without an errror message.
THANKS!!!
Sislfitz
