Beginner: Error 404 While Configuring Tailscale
Hi
I just installed HAOS on a proxmox vm. One of the add-ons I needed was Tailscale. I had downloaded the add-on from the store. Post installation, when I open up the web ui, I get a prompt from Tailscale to login. However, when clicked on the login button, the system populated as error as ‘Failed to Login’.
I enabled developer options, and could see that it shows a 404 Forbidden error code. I tried quite a few solutions which I found online, but non of them worked. Can anyone please help me to resolve this?
Just to add a bit more of details, I am able to open the tailscale online URL from my browser, and am also able to configure tailscale on the proxmox server. The problem is when it comes to configuring it on HAOS.
Some of the options which I tried:
Cleared cookies
Re-installed Tailscale add-on
Tried accessing tailscale from URL: http://:41641 - Nothing came up
Tried restarting tailscale using command ‘ha addons restart core_tailscale’ - still throws 404 error
Re-installed HAOS
Are you using Home Assistant cloud? If so try disabling it then check if you’re still denied. I had a similar issue and I know that was part of the problem.
