Beginner's question: The Matter lamp's "action: light.turn_on" command isn't working. "action: light.toggle" works
First off, hello to the community.
As a beginner, I have a question about a simple automation.
I want to turn on a Matter lamp (Ikea) using a remote control (“Philips Hue Dimmer v1” and “IKEA BILRESA E2489 Dual Button (Matter)”).
Unfortunately, “action: light.turn_on” doesn’t work.
“action: light.toggle” works.
I can turn on the Matter lamp via the dashboard.
Am I doing something wrong?
A Hue lamp connected via Z2M works with “action: light.turn_on” without any issues.
Is this a problem with Matter lamps or a mistake on my part?
Thanks in advance.
Juergen
The following YAML code works flawlessly for my IKEA matter bulb:
data: {}
  entity_id: light.lampe_mitte
Try restarting your Matter integration.
Thx, I tried it and if the action has been reduced to simply “turning on,” the lamp will turn on as desired.
The “Turn on” action, duplicated with or without a “delay” but using the desired settings, subsequently worked to turn on the lamp.
see Anfängerfrage: Matterlampe "action: light.turn_on" funktioniert nicht. "action: light.toggle" funktioniert - #3 von Speedy_99 - Automationen - simon42 Community
