Hi all,
I’ve published a custom integration for Bentel Absoluta alarm panels. It talks directly to the ABS-IP module using Bentel’s ITv2 protocol over TCP: fully local, no cloud, no MQTT bridge.
What you get
- Alarm panel per partition, plus an “All partitions” panel
- Zone sensors (open, tamper, fault, low battery, alarm, bypassed) and zone bypass switches
- Programmable outputs, remote commands and arming modes A–D, with names read from the panel
- Troubles sensor, last event from the panel log, clock sync
- Events for automations, diagnostics, English and Italian UI
Requirements: ITv2 enabled on the ABS-IP (port 3064, no encryption) and a user PIN.
Install: HACS → Custom repositories → https://github.com/valerix85/bentelalarm_for_ha (Integration). Inclusion in the default HACS store is pending.
It’s tested on an Absoluta 16, firmware 3.60. If you have a different model or firmware I’d really appreciate feedback. Please open an issue with the diagnostics file attached, the template asks for everything needed.
