I bought a Besder camera on Ali and it has two options for connectivity - 1) a wired port and 2) Wifi.
And I’m observing weird behavior for HA integration:
- Using wired port
a. RTSP - works fine
b. ONVIF - the camera shows up in auto scan and configures fine - WiFi mode
b. ONVIF - does not show up and manual configuration also fails
So two questions:
- Is there more to Wifi and ONVIF integration or is it an expected behaviour?
- What details should I post here as there are no config files and integration UI is minimalistic?
Thanks.
