Best compatible short RGB LED Strips?
is there a list of Home Assistant compatible RGB LED Light Strips somewhere by any chance?
I am using Philips Hue Strips so far, but now need a bunch of strips that are only around 40cm long. So using Hues for that would be quite a waste since I’d have to cut off more than 75% of them.
Anyone have a recommendation for a good compatible brand? Or even a list of which ones work and which don’t?
Thank you~
Ari
What is the use case? all strips have to be controlled by single controller (the same color/brightness at time)? or each one is going to emit different light?
Both is fine to be honest - no big preference there.
They will go into a vertical stacked shelf, four 40cm light strips in total.
If they are all controlled by a single controller, then the cable that connects them from one to another needs to be fairly long, about 1-2m in order to be properly hidden from sight.
