Best practice for managing a group/sets of devices
Hi All,
I have a few Shelly switches deployed around my house with more coming (although I suspect my question applies to a lot of device types), and I am trying to work out the best way of dealing with them in HA. Specifically I have a couple of different scenarios that I am trying to find the best way for, mainly regarding how to avoid duplication.
Firstly, automations. I have a common automation that applies to all the devices that triggers based on an entity state change. Now I know I can list multiple entities in the trigger of the automation, or I can put all the entities in a group and trigger the automation based on the group state, but both of these approaches require me to remember to add an entitiy when I add another device. It would be better is the new entity was ‘discovered’ when I add the device, is there a best practice way of achieving this?
Secondly, lovelace dashboards. I have a template set of cards I display for each device. At the moment I need to duplicate the cards each time I add a device, but again it would be great if there is a way of ‘discovering’ the new device and automatically creating the additional elements. I know there is the auto-entity card, but it only seems to support using a single card type for the repeated elements. Is there another way I can handle this?
Appreciate any suggestions of recomendations you can provide. The scenarios above I have simplified, but hopfully they are enough of an example to demonstrait the reuse/repeat patterns I am trying to use with my config.
Cheers
Sam
If i understand your question correctly…
Only way i know of is in configuration.yaml add groups and your entities to the groups.
example:
light:
  - platform: group
    entities:
       - light.kitchen_light
       - light.kitchen_table
       - light.cabinet_lights
also make certian you have groups enabled in configuration.yaml too:
group: !include groups.yaml
In my example your group of lights will now be “kitchen lights”
Yeas at least with groups you only have to add the new device in one place instead of all the automations and scripts.
