It has not booted up yet. It is in the Hardware check, like on a PC. Pull the plug (Network cable if PoE, USB-C if that is used, or the power brick on it).
Find a good power brick as a check (12 VDC 2 AMP)
Compatible with Pi4/Pi3B+/3B: GeeekPi Raspberry Pi 4 Power Supply USB C Power Supply is specially designed and tested for the Raspberry Pi 4; With a Type-C to Micro USB power adapter for Raspberry Pi 3B+/3B.
