Best selfmade hardware/settings for Homeassistant Assist Microphone ?!
Who can tell you where to look to compile! Hardware like yours ESP-wroom-32 + inmp441 + MAX98357A
INFO ESPHome 2025.9.3
INFO Reading configuration /config/esphome/voice-assistant.yaml...
INFO Updating https://github.com/esphome/esphome.git@pull/5230/head
WARNING GPIO12 is a strapping PIN and should only be used for I/O with care.
Attaching external pullup/down resistors to strapping pins can cause unexpected failures.
See https://esphome.io/guides/faq.html#why-am-i-getting-a-warning-about-strapping-pins
INFO Generating C++ source...
WARNING The refresh, components and submodules parameters in add_idf_component() are deprecated and will be removed in ESPHome 2026.1. If you are seeing this, report an issue to the external_component author and ask them to update it.
INFO Compiling app...
Processing living-room-voice-assistant (board: esp32dev; framework: espidf; platform: https://github.com/pioarduino/platform-espressif32/releases/download/54.03.21-2/platform-espressif32.zip)
INFO Package configuration completed successfully
HARDWARE: ESP32 240MHz, 320KB RAM, 4MB Flash
 - framework-espidf @ 3.50402.0 (5.4.2)
 - tool-cmake @ 3.30.2
 - tool-esp-rom-elfs @ 2024.10.11
 - tool-esptoolpy @ 5.0.2
 - tool-mklittlefs @ 3.2.0
 - tool-ninja @ 1.13.1
 - tool-scons @ 4.40801.0 (4.8.1)
 - toolchain-xtensa-esp-elf @ 14.2.0+20241119
Warning! Could not find file "duer_profile"
Reading CMake configuration...
-- git rev-parse returned 'fatal: not a git repository (or any parent up to mount point /)
Stopping at filesystem boundary (GIT_DISCOVERY_ACROSS_FILESYSTEM not set).'
-- Building ESP-IDF components for target esp32
Invalid field "dependencies:*": Invalid component name
-- Configuring incomplete, errors occurred!
CMake Error at /data/cache/platformio/packages/framework-espidf/tools/cmake/build.cmake:620 (message):
  ERROR: Manifest is not valid
Call Stack (most recent call first):
  /data/cache/platformio/packages/framework-espidf/tools/cmake/project.cmake:718 (idf_build_process)
  CMakeLists.txt:3 (project)
========================== [FAILED] Took 2.11 seconds ==========================
