Best Swimming Pool monitoring solution: ORP, Ph, temp
Hello together,
I had also issues with the measuring of w2839. When the pump is switched of and a couple of minutes after measuring start the values are not accurated.
For this reason I have connected the peristaltic pump to a separate Tuya WIFI switch that also controls the filter pump.
All values can be ready easily with the tuya local integration.
For visalisation I have used pool monitor card.
YAML automation for pool dosing independent from W2839:
  • switch.schwimmbad_steuerung_schalter_1 = chlorine dosing
  • switch.schwimmbad_steuerung_schalter_2 = PH minus dosing
  • switch.schwimmbad_steuerung_schalter_3 = Filter Pump control
YAML Code
alias: Schwimmbad Automatik Dosierung
description: PH und ORP Regelung
triggers:
  - entity_id:
      - switch.schwimmbad_steuerung_schalter_3
    trigger: state
    to: "on"
actions:
  - action: switch.turn_off
    metadata: {}
      entity_id:
        - switch.schwimmbad_steuerung_schalter_1
        - switch.schwimmbad_steuerung_schalter_2
    data: {}
  - alias: 15min Warten um die Messung zu stabilisieren
    delay:
      hours: 0
      minutes: 15
      seconds: 0
      milliseconds: 0
  - repeat:
      while:
        - condition: state
          entity_id: switch.schwimmbad_steuerung_schalter_3
          state: "on"
      sequence:
        - choose:
            - conditions:
                - condition: or
                  conditions:
                    - condition: numeric_state
                      entity_id: sensor.schwimmbad_monitor_orp
                      above: 1000
                      below: 200
                      entity_id: sensor.schwimmbad_monitor_ph
                      below: 3
                      above: 9
              sequence:
                - data:
                    title: Schwimmbad Alarm
                    message: >
                      Ungültige Messwerte erkannt. PH={{
                      states('sensor.schwimmbad_monitor_ph') }} ORP={{
                      states('sensor.schwimmbad_monitor_orp') }} Temperatur={{
                      states('sensor.schwimmbad_monitor_temperatur') }}
                    notification_id: schwimmbad_warnung_sensor
                  action: persistent_notification.create
              alias: Fehlerprüfung Wertebereich
            - conditions:
                  below: 7
              sequence:
                - action: persistent_notification.create
                    title: Schwimmbad Warnung
                    message: >
                      pH-Wert zu niedrig: {{
                      states('sensor.schwimmbad_monitor_ph') }}. Keine
                      Chlor-Dosierung aktiv.
                    notification_id: schwimmbad_warnung_ph
              alias: Wenn ph < 7.0 - Dosierung inaktiv
            - conditions:
                  above: 780
              sequence:
                - data:
                    message: >
                      ORP ist hoch: {{states('sensor.schwimmbad_monitor_orp') }}
                      mV
                    notification_id: schwimmbad_warnung_orp
              alias: Warnung wenn ORP zu hoch
            - conditions:
                  above: 7.3
              sequence:
                - condition: state
                  state: "on"
                - target:
                    entity_id: switch.schwimmbad_steuerung_schalter_2
                  action: switch.turn_on
                  data: {}
                - delay:
                    seconds: 15
                - target:
                  data: {}
              alias: Wenn ph > 7.3 ZUERST PH senken
            - conditions:
                - condition: and
                  conditions:
                      above: 7.1
                      below: 7.3
                      below: 700
                      entity_id: sensor.schwimmbad_monitor_temperatur
                      above: 15
              sequence:
                - condition: state
                  state: "on"
                - target:
                    entity_id: switch.schwimmbad_steuerung_schalter_1
                - delay:
                    seconds: 10
                - target:
              alias: Wenn PH OK (7.1 - 7.3) und ORP<700, dann ORP heben
        - alias: >-
            20min warten um die Dosierung zu stabilisieren bzw. Neumessung
            durchzuführen.
          delay:
            hours: 0
            minutes: 20
            seconds: 0
            milliseconds: 0
  - alias: Dosierung deaktivieren - Sicherheitsfunktion
    repeat:
      while:
        - condition: switch.is_on
            entity_id:
          options:
            for: "00:00:00"
            behavior: any
      sequence:
          metadata: {}
            entity_id:
          data: {}
        - delay:
            hours: 0
            minutes: 0
            seconds: 1
            milliseconds: 0
mode: single
Have fun! Improvements and ideas are welcome!
Thanks Willian for your work. :blush:
I have ported your project to use the cb3s instead of replacing it with an esp32.
Github Repo W218
ran it through MS Copilot, here´s what i got:
template:
  - sensor:
      - name: "Pool Chlor"
        unique_id: pool_chlor
        unit_of_measurement: "ppm"
        device_class: water
        state: >
          {% set ph = states('sensor.sonda_piscina_ph') | float(0) | round(1) %}
          {% set orp = states('sensor.sonda_piscina_orp') | float(0) %}
          {% set werte = {
            6.5: [740.04, 141.14],
            6.6: [734.99, 139.02],
            6.7: [729.97, 136.80],
            6.8: [725.01, 134.64],
            6.9: [720.04, 132.43],
            7.0: [714.99, 130.28],
            7.1: [710.02, 128.09],
            7.2: [704.95, 125.88],
            7.3: [700.03, 123.72],
            7.4: [695.18, 121.41],
            7.5: [689.94, 119.47],
            7.6: [685.00, 117.25],
            7.7: [680.00, 115.10],
            7.8: [675.03, 112.91],
            7.9: [670.03, 110.75],
            8.0: [665.01, 108.61]
          {% if ph < 6.5 %}
            {% set ph = 6.5 %}
          {% elif ph > 8.0 %}
            {% set ph = 8.0 %}
          {% endif %}
          {% set a = werte[ph][0] %}
          {% set b = werte[ph][1] %}
          {% set chlor = e ** ((orp - a) / b) %}
          {{ [chlor, 0] | max | round(2) }}
benefits should be:
only one final sensor, source sensors get read only once, negative values are capped to 0 and easier maintenance and readabilty through the table and less if statements.
cant test it atm as my W218 still waits installation but maybe someone can test it.
big thx for your initial work!
copilot adviced, interpolation would be even better then linear approach:
        device_class: water
        state: >
          {% set ph = states('sensor.wifi_smart_online_8_in_1_tester_ph') | float(7.2) %}
          {% set orp = states('sensor.wifi_smart_online_8_in_1_tester_oxidation_reduction_potential') | float(0) %}
          {% set werte = {
          {% set ph = [8.0, [6.5, ph] | max] | min %}
          {% set ph_unten = (ph * 10) | round(0, 'floor') / 10 %}
          {% set ph_oben  = [8.0, ph_unten + 0.1] | min %}
          {% set faktor = (ph - ph_unten) / (ph_oben - ph_unten) if ph_oben != ph_unten else 0 %}
          {% set a =
            werte[ph_unten][0] +
            (werte[ph_oben][0] - werte[ph_unten][0]) * faktor
          {% set b =
            werte[ph_unten][1] +
            (werte[ph_oben][1] - werte[ph_unten][1]) * faktor
feel free to test it
I will see if I can source that here in the US. I finally installed my Atlas Scientific PMP Bx pump with ESP Home integration and I’m dosing manually based on historical data. Now to determine whether an ORP setup or Waterguru (for ease of use) is better. Quite frankly, I’d like to avoid third party stuff, but need a system that works consistently in the Florida heat.
hy, did you have any manual or how to, for flashing the device?
i did not find any useful information.
thx for your help
After 6 months of almost fulltime tinkering I have it all setup:
  • Inver Hero Variable speed pump
  • Yieryi ph W218 (updated probes)
  • Sundream LC400A Chloride elecrtolyse unit
  • Sundream TS100 Water Quality/pH pump
All monitored in HA, for now automation still running via Tuya, all available in Tuya Local.
The W218 and the TS100 differ on ORP, but the spread is stable
really nice.
how you integrate the big multi testing sonde?
can you tell me witch components are used
thx
