Best way to adjust markdown style
I added a markdown card in the dashboard. The markdown includes a table, but the styling is very poor resp. not sufficient (all too narrow, not padding, to borders etc.). Is there a way to fix this? I tried to add a .css resource, but it does not overwrite the default styles of the used Lovelace theme.
Kind regards,
BlueMonkey
Main card mod thread - 1st post - link at the bottom titled “fantastic” - markdown
Sound like a possible solution, but I do not want to make my whole dashboard with yaml. I don’t want to dive that deep in HA. Is it possible to add custom CSS or to modify the Lovelace theme? The later one is not the best solution because would have update my adjustments regularly to get the rest of the updates.
Many options in stock cards cannot be defined in UI, only in yaml. Not to mention yaml in configuration.yaml etc.
… which is also yaml.
If do not want to deal with card-mod, defining custom css is possible, for instance, in external js resources - but this is not a “stock vanilla” way…
