I’m using a Shelly Plus Uni to control my garage door:
- OUT1 is connected to the garage controller’s push button input (configured with auto-off = 0.5s)
- IN1 is connected to a reed switch to detect whether the door is fully open(i have it mounted when the door in the open position)
I’d like to create a Tile card (or custom card) in Home Assistant that displays the door status(closed, open, in-motion maybe), triggers the push button input to start moving the door and optionally shows a loading indicator or icon while the door is in motion(since the reed switch only updates after the door fully opens, no problem when it starts to close).
What i came up with, and wondering if anyone has a better solution:
- Created an input boolean helper called “garage_door_loading”
- Created 3 automations:
- one that changes the helper to “on” when the shelly switch changes to “on”
- one that sets the helper to “off” when the shelly IN1 sensor changes(to either off or on)
- one as a backup, to set the helper to “off” after a 10 second timeout after it was changed to on
And then i created a card with card-mod like so:
type: tile
entity: switch.garage_door_trigger
tap_action:
action: toggle
card_mod:
style: |
ha-card {
{% if is_state('binary_sensor.garage_door_sensor', 'off') %}
--tile-color: green !important;
--card-mod-icon: mdi:garage !important;
{% else %}
--tile-color: orange !important;
--card-mod-icon: mdi:garage-open !important;
{% endif %}
ha-card:after {
content: "";
position:absolute;
display: none;
right: 10px;
top: 50%;
width: 10px;
height: 10px;
background: lightblue;
margin-top: -5px;
animation: infinite 1s spinner;
{% if is_state('input_boolean.garage_door_loading', 'on') %}
display:block;
{% endif %}
ha-tile-info:after {
content: "In motion";
{% elif is_state('binary_sensor.garage_door_sensor', 'off') %}
content: "Closed";
{% else %}
content: "Open";
{% endif %}
position: absolute;
width: 100%;
font-size: 12px;
bottom: -2px;
background: #fff;
And this gave me a nice looking tile:
So it has a custom green / orange icon based on the sensor, a custom state text and a loading indicator when the door is in motion(in theory).
What do you think about this solution? I’m a beginner, so there might be a way simpler solution i’m not aware of.
