I see the above is supported, but can I show a sensor (from HASSIO) value (the sensor value changes evry 5-10 seconds)???
Can it be battery operated, or would it consume too much?
Yes of course you can. https://esphome.io/components/sensor/homeassistant.html
Battery power, dunno, look at the specs and do some calcs.
Anyone has some experience?
I guess I need a e-paper display (or LCD) + ESP module + enclosure + battery
Anything available on the market that is ready to use?
Google m5stack.
Thanks, that’s good idea.
You tried one of those?
Not personally.
Actually do check that the screen on that one is supported by esphome.
Hi @Klagio
I have set it up here, was a bit tricky, but it’s working.
Still have a minor issue when it’s unavailable (the sensor), that I haven’t figure out yet.
The m5stack option is expensive, but nice.
