After years of trying to get the Google Assistant integration to consistently work with local fulfillment (Google Cloud API and DuckDNS), I found Matterbridge. If you have a Matter supporting Google Home speaker/display then you can expose most HA entities to Google Assistant/Gemini locally over Matter with Matterbridge.
Key Advantages:
- Local fulfillment
- Fast
- Reliable
- HA does not need to be exposed to the internet with SSL
If you are continually frustrated by “{{entity}} offline” replies from Google Assistant/Gemini Home, check out Matterbridge.
Matterbridge should be mentioned on the Google Assistant page. It is a game changer.
It may also work for exposing HA entities to Alexa.
I followed this YouTube video.
