I am trying to add more than 30 smart switches in a 3 storey house. the HA is placed in the GF and I have smart switches which support Zigbee 3.0 across the house.
I am wondering how I can improve the coverage? sometimes it takes along time for HA to find a new device. Also when I run in it tries to add all the switches all at ones.
I also have 3 Unifi WiFi 6 Wireless access points across the house.
Which integration are you using to add your devices? Is it ZHA, Z2MQTT or something else?
Asking because I’ve never seen the behaviour you described. Neither ZHA nor Z2M have autodiscovery, and they will only try to add device which are actively in pairing mode.
Please read the pinned topic and provide more details
it depends on the wiring.
If they are wired with neutral then they are, but if you have smart switch with only two wires, without neutral, then they are not
Well i have switches that can be wired with and without neutral. The one that is wired with neutral is acting as router, other without neutral is acting as end device.
Every switch that i have and is wired with neutral is acting as router.
Other that have live and light wire connected are end devices.
Were you going to provide additional context? It may be helpful to the OP by providing the brand you are referencing. Stating No Neutral routers don’t exist is not helpful. They do exist, I have a few.
Thanks for the information. All my switches have Neutral as well and I believe they’re all acting as router as I don’t have issue reaching far ends of the house in different floors, but some switches are stuck in pairing mode and HA is not able to find them.
How can I make sure that a device is Router or End Device?
This is a sample of my switches
