Hi All,
I’m looking for a TRV which supports the following things:
Integration can be ZHA(with Sky-Stick) or Z-WaveJS(UZB USB-Stick), eventually Matter with the Sky-Connect.
- Shows Valve opening in %, at least on(open) or off(close)
- can use external temperature sensor
- reacts fast when I change the Temperatur
- builtin rechargeable battery, or can be used with AA or AAA rechargeble batteries
- eventually there exists TRVs with an internal Heating Plan, as some Bluetooth TRV I used before
It would be fine to use an internal heating plan, so I don’t have to Set up Automations. I’ve tested Better Thermostat with my TRVs and none of them is working good.
I have tested the following TRVs: Eurotronics Spirit Zwave, Fibaro FGT-001, Tuya TR0601, Shelly TRV.
The Spirit loses sporadically the connection. Fibaro heats though it’s warm enough. Tuya doesn’t keep the Temperatur very well. Shelly works, but mostly it done off on and is pricey😉, whether the Spirit regulates very fine. Has anyone a recommendation? Sorry for my bad English but it’s been a long time since I went to school.
Greetings from Westphalia
Tom
PS.: I’ve made another Thread trying to solve the Problems with the Spirit, when he works, he works well.
