[BETA] HA Client - native Android client for Home Assistant
android
Tags: #<Tag:0x00007fd08543fd48>
#327
Unfortunately it is not possible yet to apply CSS to flutter widgets.
#328
Moved to a new website: http://ha-client.vynn.co/
#329
How about making the UI more similar to the web app?
The differences are subtle, but in my opinion the web app looks better.
Also, can the alarm card be configured to be used without PIN? Now it can be used with a blank pin, but could it be hidden?
Now, I realize looks are something less important than functionality, but I wanted to give a few suggestions anyway. Thank you for your hard work. This is IMO the best native app at the moment.
#330
Hi @areks
I see several issues here. On a first screen your alarm panel card is not rendered as alarm panel. It is rendered as entities card. Could you please report this issue on GitHub? Thanks.
The second thing - I don’t see any attribute to determine that current alarm is requires no pin, except code_format is null. Please report this as a separate issue as well. I will try to figure it out. Thanks.
#331
Could it be because I’m using a custom view? (this one: Lovelace: Alarm card)
#332
Possible, use the standard one
#333
@areks, yes. Custom cards is not supported
#334
Bedside I think they have basically the same functionality
#335
I don’t use the standard one because I’m stuck with a full number pad and I don’t use a pin code. But thanks for the suggestion!
#336
I see the issue. I’ll implement this functionality in next version: hide pin pad if code_format is null.
#337
Dear all.
  1. Discord server will be closed on Feb 20th due to it’s useless.
  2. Reed news on HAClient in my blog: http://homemade.systems
#338
New version 0.4.0 out. This is the best Home Assistant Android client available
#339
The new colour picker its great
#340
Yeah, new color picker is awesome!
What was wrong with pull to refresh tho?
#341
Thanks @Kvasenok and @Klagio, I love it too! ))
Pull to refresh was for updating all UI from server. The same is done by app automatically when it starts or goes from background. Even when you lock your device’s screen with app on top and unlock it back - the app updates all UI as well. So manual refresh is not so useful. The second reason I removed it is preparing for multiple columns support for landscape and tablets. It will be very hard to implement if “pull to refresh” will still be there.
#342
How version 4.0 support streaming from camera? How I must add it to lovelace in Home Assistant?
And in version series 4.0 long name entity still no looks good. Still not show full name and show…
#343
Just open any camera entity. It is supported only there for now, on entity view.
#344
Hi, I also do not understand well: I do see the circle with the picture inside, but clickink on it brings out the full menu (access_token, file_path, friendly_name and so on), but no camera image or stream.
I tried both with generic and ffmpeg
  - platform: ffmpeg
    input: rtsp://admin:[email protected]:554/rtsp_live0
  - platform: generic
    still_image_url: http://192.168.1.12/snapshot.cgi?user=admin&pwd=xxxxxxx
  - platform: generic
    still_image_url: http://admin:[email protected]/ISAPI/Streaming/channels/101/picture
#345
Please report this to github. Thanks
#346
No doubt I am new to this… what is “token” on connection info. Is this the duckdns token?
