Home Assistant Community
[BETA] HA Client - native Android client for Home Assistant
android
Tags: #<Tag:0x00007f3774dd79a0>
#22
Me too. I am with 0.78.3
I access with http and I put my hass address 192.168.1.1
#23
It looks like the issue with local IP connection. I’ll test on my setup
#24
Could you access your web interface with the same IP, http protocol and the same port you use in app?
#25
I am not sure i understand.
I always access HASS with my browser at http://192.168.1.1:8123
of course locally under WiFi
#26
Good. Did you use just a password to login to HASS, or you are using new auth system with username and password?
#27
#28
Ok. Now please show me a screenshot of your app settings. You can send it in private message if you want.
#29
#30
Thanks. It seams all should be fine. I’m checking the same config on my Hass.io now.
#31
I changed the access token putting a wrong one, and it gave error token wrong, so it does connect to HASS for that at least
#32
@Klagio
That is rather weird IP address. What’s your router IP address then?
#33
192.168.1.254
#34
@Klagio
Aaa, i see. That is clear now. :wink:
#35
I see now. Looks like it is an error in parsing entities. I’ll add handling parse errors in visual way in next build to know which entity cause error.
#36
thank you, hoping for the fix
One thing I noticed so far. App show states as oryginal values. Example below (home, not_home) instead Home, Away?
#38
Now it shows only state field value. Translations and friendly states are planned.
#39
@estevez
Aaa, ok. Sorry. Didn’t know. Thanks for that.
#40
I’m excited to get a client that is faster than the web app. Will you be posting the code somewhere?
#41
I’m still thinking about it.
