Better Logging for AppDaemon Apps
Not sure if this has been posted here before, but hats off to Jason Antman, who’s come up with a pretty awesome, more Pythonic way of logging in AppDaemon apps: Better Logging for AppDaemon Apps - Jason Antman's Blog. In summary:
So far this seems to be working quite well for me, and allowing me to have a much better experience with developing, debugging and testing AppDaemon apps. Perhaps it will be useful to someone else as well.
I’m going to try that out for sure.
Another tip for those using hass.io:
watching logs over samba mounted dir is very slow for me thus I do this instead:
Enable logging in appdaemon.yaml:
log:
  logfile: /config/appdaemon/appdaemon.log
  errorfile: /config/appdaemon/appdaemon.log
Get access to ssh to hass.io as described at https://developers.home-assistant.io/docs/en/hassio_debugging.html
then you can do as follows:
$ ssh [email protected] -p 22222
$ login
$ docker exec -it `docker ps -aqf "ancestor=hassioaddons/appdaemon3-armhf"` /bin/bash
$  tail -f /config/appdaemon/appdaemon.log
this gives instant feedback as opposed to several seconds and sometimes no updates when using tail -f on smb mounted directories.
its going from the wrong assumption that you cant set levels in the log.
i think thats strange because the docs clearly state that you can set levels.
I saw that article, and I am thinking of ways to integrate this - my original goal was simplicity, and the ability to be explicit about which app was logging, it can definitely be improved on though.
Btw. I tried using it but stopped as it for some reason stopped normal logging and exceptions was no longer printed.
