Better notification of errors and inbuilt database recovery
Over the past few months I have lost valuable statistical data that I am not able to access any more. As time goes on the statistics are more and more important but HA does very little to help when things go wrong
  1. More robustness in the database design to prevent failures from corrupting the database, and when a corruption does occur more effort by HA to recover and restore.
  2. There needs to be a repair action alert when the database has an issue. At present a corrupt database is simply renamed and a new one added… this error does show up in the log but unless you look there every day its easily missed. If you restart its lost all together.
  3. In the event of issues where the database is renamed and a new one created HA needs to provide users with an easy to use method of merging a backup of the database to the live database, or recovering data from the renamed “corrupt” database and merging into the new live version.
Worst case, If I knew the database had been corrupted when the system started, I could recover from backup and restore… I may loose a day of data but that’s better than loosing months of statistics.
Better case would be to be able to restore up to the last write from a database log.
ideal would be, in the event of failure, for HA to offer recover from backup and data recovery during startup rather than just renaming and continuing.
