Better state history
Hi, is there any plugin or modification available to get a better state history panel?
Let me specify why:
I was trying to use the default which comes with HA, and it’s … sorry to say … but at time of writing quite unusable.
Even with only a handful of (temperature) sensors enabled, the graphs make the history panel grind to a stop - It’s just too much data apparently, and that is when I click on just “3 days”. It takes almost a whole minute before anything shows up. Even showing up, it jumps forwards and backwards between a “1 day” and “3 days” view (just the graphs) and sometimes before it “decides” to stay on one, the whole thing breaks apart and stops loading altogether, forcing me to close the browser and reopen it.
A solution would be to fetch only 1/10 or 1/20 of the data to show on the graphs, because loading every second within 3 days is just too much, even more when using more than 1 sensor.
Well, I don’t know who more faces this problem (probably anyone who tried to use the panel seriously), but I would love to hear more people talking about this.
A little bit of topic edit: Furthermore, the design of those graphs in the whole HA are quite old looking, I would love to see someone replacing those with a nice JS for graphs, such as ChartJS or something like that. Those are beautiful, I would love to see them in HA as default.
EDIT: Yeah, what I’ve imagined…
That’s a ridiculous amount of data to display, no wonder it breaks. It probably also tries to display all those.
So, if my screen width is 1920px, it’s useless to load more…
Have a look at grafana
Use HA to push data in an influx DB and, as @djeclemen suggested, use grafana to display whatever you need.
If you use hassIo it’s pretty straightforward, otherwise just google TIG stack to get info on the subject.
