Better Thermostat Card - Configuration Error
A few weeks ago I did an upgrade to the Better Themostat card - I use it for displaying each Thermostat in my Drayton Wiser configuration.
However, I'm now getting the following on my dashboard:
Configuration error
  • Custom element not found: better-thermostat-ui-card
The YAML code is as follows:
type: custom:better-thermostat-ui-card
entity: climate.wiser_lounge_dining_room
I seem to have both of the following installed from HACS:
  • Better Thermostat UI (not sure this works with the Drayton Wiser system?)
  • Better Thermostat
Any thoughts?
See Release 3.0.0 · KartoffelToby/better-thermostat-ui-card · GitHub
BREAKING CHANGES
The Type is changed, now there are two card types, normal and mini
type: custom:better-thermostat-normal-climate-card
type: custom:better-thermostat-mini-climate-card
Had same problem, now solved.
