I have some of Google Home speakers around the place and each of them have a different volume and some of them are hidden behind the TV so I cannot simply set the volume and reset it after each speech.
Whatever reason if I interact with the Google Home normally I can hear the reply.
With TTS it is so soft I cannot hear it unless I’m standing right next to it. I have to add 60 DB to make it sound like normal replies.
It seems Google is the only one that can take this setting?
Because each speaker has a different default volume and I called the TtS with a different speaker each time then it’s going to be very hard to write some code that has all this information in
