For anyone with a BG Sync EV charger. The standard OCPP integration mostly works but I hit a few device specific issues, so I’ve forked it and fixed them. Sharing in case it saves someone else the pain.
Full credit to @lbbrhzn, this is built entirely on top of the original OCPP integration. Fair warning, a decent chunk of the code was written with AI help (Claude), but it’s all been tested on my own charger.
Fixes:
- Switches no longer get stuck after an HA restart
- Better handling of BG Sync’s protocol quirks
Added:
- Cable release protection, toggle whether the cable auto releases at the end of charging or stays locked until you release it in HA
- LED brightness control for the outside charging port
- EVCC compatible, useful for excess solar charge control
Plus all the usual OCPP stuff, start/stop charging, current limiting, power/voltage/temp monitoring, configurable meter intervals.
Install:
Install via HACS (add the repo as a custom repository), or grab the latest release or just clone it and copy custom_components/ocpp into your custom_components directory. Full steps in the repo README.
Then restart HA, add the OCPP integration via Settings > Devices & Services (it listens on port 9000 by default), and point your charger at Home Assistant by setting its OCPP server URL to ws://<your_HA_IP>:9000. That last step is the one that catches people out, with OCPP the charger connects to HA, not the other way round.
Example, LED brightness automation:
This is the one I actually run. Dims the indicator LED to 1% at dusk so it doesn’t light up the drive all night, back to 30% at dawn.
alias: Charger LED Day/Night Brightness
description: Full brightness at sunrise, dims to 1% at sunset
triggers:
- trigger: sun
event: sunrise
- trigger: sun
event: sunset
actions:
- choose:
- conditions:
- condition: trigger
sequence:
- action: number.set_value
entity_id: number.charger_indicator_led_brightness
value: 30
- conditions:
sequence:
value: 1
mode: single
Swap charger for your charger’s entity prefix.
main tracks upstream unchanged, the default bg-sync-custom branch carries the BG Sync changes on top, so upstream improvements merge in easily.
Been running it for a while now, no issues. Raise anything BG Sync specific on my repo, anything general OCPP belongs upstream.
Happy to answer questions.
