And here is the code of the yaml who give troubles to the ESP8266, and never come back after the update giving a booting problem :
logs_luxeflex-trap_run [update to 2026.3.0].txt :
type or paste code here
INFO ESPHome 2026.3.0
INFO Reading configuration /config/esphome/luxeflex-trap.yaml...
INFO Detected timezone 'Europe/Amsterdam'
INFO Generating C++ source...
INFO Compiling app... Build path: /data/.build/luxeflex-trap
Processing luxeflex-trap (board: d1_mini; framework: arduino; platform: platformio/[email protected])
Removing unused dependencies...
Library Manager: Removing noise-c @ 0.1.10
INFO Removing noise-c @ 0.1.10
Library Manager: Removing dependencies...
INFO Removing dependencies...
Library Manager: Removing libsodium @ 1.10020.7
INFO Removing libsodium @ 1.10020.7
Library Manager: [email protected] has been removed!
INFO [email protected] has been removed!
Library Manager: Installing esphome/noise-c @ 0.1.11
INFO Installing esphome/noise-c @ 0.1.11
Unpacking [####################################] 100%
Library Manager: [email protected] has been installed!
INFO [email protected] has been installed!
Library Manager: Resolving dependencies...
INFO Resolving dependencies...
Library Manager: Installing esphome/libsodium @ 1.10021.0
INFO Installing esphome/libsodium @ 1.10021.0
HARDWARE: ESP8266 80MHz, 80KB RAM, 4MB Flash
ESPHome: Excluding Updater.cpp from build (using native OTA backend)
ESPHome: Excluding core_esp8266_waveform_phase.cpp from build (waveform not required)
ESPHome: Excluding core_esp8266_waveform_pwm.cpp from build (waveform not required)
Dependency Graph
|-- ESPAsyncTCP @ 2.0.0
|-- ESP8266WiFi @ 1.0
|-- ESPAsyncWebServer @ 3.9.6
|-- DNSServer @ 1.1.1
|-- ESP8266mDNS @ 1.2
|-- ArduinoJson @ 7.4.2
|-- noise-c @ 0.1.11
Compiling .pioenvs/luxeflex-trap/src/esphome/components/a4988/a4988.cpp.o
Compiling .pioenvs/luxeflex-trap/src/esphome/components/adc/adc_sensor_common.cpp.o
Compiling .pioenvs/luxeflex-trap/src/esphome/components/adc/adc_sensor_esp8266.cpp.o
Compiling .pioenvs/luxeflex-trap/src/esphome/components/api/api_buffer.cpp.o
Compiling .pioenvs/luxeflex-trap/src/esphome/components/api/api_connection.cpp.o
Compiling .pioenvs/luxeflex-trap/src/esphome/components/api/api_frame_helper.cpp.o
Compiling .pioenvs/luxeflex-trap/src/esphome/components/api/api_frame_helper_noise.cpp.o
Compiling .pioenvs/luxeflex-trap/src/esphome/components/api/api_pb2.cpp.o
Compiling .pioenvs/luxeflex-trap/src/esphome/components/api/api_pb2_dump.cpp.o
Compiling .pioenvs/luxeflex-trap/src/esphome/components/api/api_pb2_service.cpp.o
Compiling .pioenvs/luxeflex-trap/src/esphome/components/api/api_server.cpp.o
Compiling .pioenvs/luxeflex-trap/src/esphome/components/api/list_entities.cpp.o
src/esphome/components/api/api_pb2_dump.cpp:70:13: warning: 'void esphome::api::dump_field(esphome::api::DumpBuffer&, const char*, const string&, int)' defined but not used [-Wunused-function]
70 | static void dump_field(DumpBuffer &out, const char *field_name, const std::string &value, int indent = 2) {
src/esphome/components/api/api_pb2_dump.cpp:59:13: warning: 'void esphome::api::dump_field(esphome::api::DumpBuffer&, const char*, uint64_t, int)' defined but not used [-Wunused-function]
59 | static void dump_field(DumpBuffer &out, const char *field_name, uint64_t value, int indent = 2) {
Compiling .pioenvs/luxeflex-trap/src/esphome/components/api/proto.cpp.o
Compiling .pioenvs/luxeflex-trap/src/esphome/components/api/subscribe_state.cpp.o
Compiling .pioenvs/luxeflex-trap/src/esphome/components/binary_sensor/automation.cpp.o
8< ----
I cut here a big part due the max text I can put here
8< ----
Compiling .pioenvs/luxeflex-trap/lib1ae/noise-c/crypto/donna/curve25519-donna.c.o
Compiling .pioenvs/luxeflex-trap/lib1ae/noise-c/crypto/donna/poly1305-donna.c.o
Compiling .pioenvs/luxeflex-trap/lib1ae/noise-c/crypto/sha2/sha256.c.o
Compiling .pioenvs/luxeflex-trap/lib1ae/noise-c/crypto/sha2/sha512.c.o
Compiling .pioenvs/luxeflex-trap/lib1ae/noise-c/crypto/x25519/x25519.c.o
Compiling .pioenvs/luxeflex-trap/lib1ae/noise-c/protocol/cipherstate.c.o
Compiling .pioenvs/luxeflex-trap/lib1ae/noise-c/protocol/dhstate.c.o
Compiling .pioenvs/luxeflex-trap/lib1ae/noise-c/protocol/errors.c.o
Archiving .pioenvs/luxeflex-trap/libd42/libsodium.a
Indexing .pioenvs/luxeflex-trap/libd42/libsodium.a
Compiling .pioenvs/luxeflex-trap/lib1ae/noise-c/protocol/handshakestate.c.o
Compiling .pioenvs/luxeflex-trap/lib1ae/noise-c/protocol/hashstate.c.o
Compiling .pioenvs/luxeflex-trap/lib1ae/noise-c/protocol/internal.c.o
Compiling .pioenvs/luxeflex-trap/lib1ae/noise-c/protocol/names.c.o
Compiling .pioenvs/luxeflex-trap/lib1ae/noise-c/protocol/patterns.c.o
Compiling .pioenvs/luxeflex-trap/lib1ae/noise-c/protocol/rand_os.c.o
Compiling .pioenvs/luxeflex-trap/lib1ae/noise-c/protocol/rand_sodium.c.o
Compiling .pioenvs/luxeflex-trap/lib1ae/noise-c/protocol/randstate.c.o
Compiling .pioenvs/luxeflex-trap/lib1ae/noise-c/protocol/signstate.c.o
Compiling .pioenvs/luxeflex-trap/lib1ae/noise-c/protocol/symmetricstate.c.o
Compiling .pioenvs/luxeflex-trap/lib1ae/noise-c/protocol/util.c.o
Archiving .pioenvs/luxeflex-trap/libFrameworkArduinoVariant.a
Indexing .pioenvs/luxeflex-trap/libFrameworkArduinoVariant.a
Compiling .pioenvs/luxeflex-trap/FrameworkArduino/Crypto.cpp.o
Compiling .pioenvs/luxeflex-trap/FrameworkArduino/Esp-frag.cpp.o
Compiling .pioenvs/luxeflex-trap/FrameworkArduino/Esp-version.cpp.o
Archiving .pioenvs/luxeflex-trap/lib1ae/libnoise-c.a
Indexing .pioenvs/luxeflex-trap/lib1ae/libnoise-c.a
Compiling .pioenvs/luxeflex-trap/FrameworkArduino/Esp.cpp.o
Compiling .pioenvs/luxeflex-trap/FrameworkArduino/FS.cpp.o
Compiling .pioenvs/luxeflex-trap/FrameworkArduino/FSnoop.cpp.o
Compiling .pioenvs/luxeflex-trap/FrameworkArduino/FunctionalInterrupt.cpp.o
Compiling .pioenvs/luxeflex-trap/FrameworkArduino/HardwareSerial.cpp.o
Compiling .pioenvs/luxeflex-trap/FrameworkArduino/IPAddress.cpp.o
Compiling .pioenvs/luxeflex-trap/FrameworkArduino/LwipDhcpServer-NonOS.cpp.o
Compiling .pioenvs/luxeflex-trap/FrameworkArduino/LwipDhcpServer.cpp.o
Compiling .pioenvs/luxeflex-trap/FrameworkArduino/LwipIntf.cpp.o
Compiling .pioenvs/luxeflex-trap/FrameworkArduino/LwipIntfCB.cpp.o
Compiling .pioenvs/luxeflex-trap/FrameworkArduino/MD5Builder.cpp.o
Compiling .pioenvs/luxeflex-trap/FrameworkArduino/Print.cpp.o
Compiling .pioenvs/luxeflex-trap/FrameworkArduino/Schedule.cpp.o
Compiling .pioenvs/luxeflex-trap/FrameworkArduino/StackThunk.cpp.o
Compiling .pioenvs/luxeflex-trap/FrameworkArduino/Stream.cpp.o
Compiling .pioenvs/luxeflex-trap/FrameworkArduino/StreamSend.cpp.o
Compiling .pioenvs/luxeflex-trap/FrameworkArduino/Tone.cpp.o
Compiling .pioenvs/luxeflex-trap/FrameworkArduino/TypeConversion.cpp.o
Compiling .pioenvs/luxeflex-trap/FrameworkArduino/WMath.cpp.o
Compiling .pioenvs/luxeflex-trap/FrameworkArduino/WString.cpp.o
Compiling .pioenvs/luxeflex-trap/FrameworkArduino/abi.cpp.o
Compiling .pioenvs/luxeflex-trap/FrameworkArduino/aes_unwrap.cpp.o
Compiling .pioenvs/luxeflex-trap/FrameworkArduino/base64.cpp.o
Compiling .pioenvs/luxeflex-trap/FrameworkArduino/cbuf.cpp.o
Compiling .pioenvs/luxeflex-trap/FrameworkArduino/cont.S.o
Compiling .pioenvs/luxeflex-trap/FrameworkArduino/cont_util.cpp.o
Compiling .pioenvs/luxeflex-trap/FrameworkArduino/core_esp8266_app_entry_noextra4k.cpp.o
Compiling .pioenvs/luxeflex-trap/FrameworkArduino/core_esp8266_eboot_command.cpp.o
Compiling .pioenvs/luxeflex-trap/FrameworkArduino/core_esp8266_features.cpp.o
Compiling .pioenvs/luxeflex-trap/FrameworkArduino/core_esp8266_flash_quirks.cpp.o
Compiling .pioenvs/luxeflex-trap/FrameworkArduino/core_esp8266_flash_utils.cpp.o
Compiling .pioenvs/luxeflex-trap/FrameworkArduino/core_esp8266_i2s.cpp.o
Compiling .pioenvs/luxeflex-trap/FrameworkArduino/core_esp8266_main.cpp.o
Compiling .pioenvs/luxeflex-trap/FrameworkArduino/core_esp8266_non32xfer.cpp.o
Compiling .pioenvs/luxeflex-trap/FrameworkArduino/core_esp8266_noniso.cpp.o
Compiling .pioenvs/luxeflex-trap/FrameworkArduino/core_esp8266_phy.cpp.o
Compiling .pioenvs/luxeflex-trap/FrameworkArduino/core_esp8266_postmortem.cpp.o
Compiling .pioenvs/luxeflex-trap/FrameworkArduino/core_esp8266_si2c.cpp.o
Compiling .pioenvs/luxeflex-trap/FrameworkArduino/core_esp8266_sigma_delta.cpp.o
Compiling .pioenvs/luxeflex-trap/FrameworkArduino/core_esp8266_spi_utils.cpp.o
Compiling .pioenvs/luxeflex-trap/FrameworkArduino/core_esp8266_timer.cpp.o
Compiling .pioenvs/luxeflex-trap/FrameworkArduino/core_esp8266_vm.cpp.o
Compiling .pioenvs/luxeflex-trap/FrameworkArduino/core_esp8266_wiring.cpp.o
Compiling .pioenvs/luxeflex-trap/FrameworkArduino/core_esp8266_wiring_analog.cpp.o
Compiling .pioenvs/luxeflex-trap/FrameworkArduino/core_esp8266_wiring_digital.cpp.o
Compiling .pioenvs/luxeflex-trap/FrameworkArduino/core_esp8266_wiring_pulse.cpp.o
Compiling .pioenvs/luxeflex-trap/FrameworkArduino/core_esp8266_wiring_pwm.cpp.o
Compiling .pioenvs/luxeflex-trap/FrameworkArduino/core_esp8266_wiring_shift.cpp.o
Compiling .pioenvs/luxeflex-trap/FrameworkArduino/crc32.cpp.o
Compiling .pioenvs/luxeflex-trap/FrameworkArduino/debug.cpp.o
Compiling .pioenvs/luxeflex-trap/FrameworkArduino/exc-c-wrapper-handler.S.o
Compiling .pioenvs/luxeflex-trap/FrameworkArduino/exc-sethandler.cpp.o
Compiling .pioenvs/luxeflex-trap/FrameworkArduino/flash_hal.cpp.o
Compiling .pioenvs/luxeflex-trap/FrameworkArduino/gdb_hooks.cpp.o
Compiling .pioenvs/luxeflex-trap/FrameworkArduino/heap.cpp.o
Compiling .pioenvs/luxeflex-trap/FrameworkArduino/hwdt_app_entry.cpp.o
Compiling .pioenvs/luxeflex-trap/FrameworkArduino/libb64/cdecode.cpp.o
Compiling .pioenvs/luxeflex-trap/FrameworkArduino/libb64/cencode.cpp.o
Compiling .pioenvs/luxeflex-trap/FrameworkArduino/libc_replacements.cpp.o
Compiling .pioenvs/luxeflex-trap/FrameworkArduino/mmu_iram.cpp.o
Compiling .pioenvs/luxeflex-trap/FrameworkArduino/reboot_uart_dwnld.cpp.o
Compiling .pioenvs/luxeflex-trap/FrameworkArduino/spiffs/spiffs_cache.cpp.o
Compiling .pioenvs/luxeflex-trap/FrameworkArduino/spiffs/spiffs_check.cpp.o
Compiling .pioenvs/luxeflex-trap/FrameworkArduino/spiffs/spiffs_gc.cpp.o
Compiling .pioenvs/luxeflex-trap/FrameworkArduino/spiffs/spiffs_hydrogen.cpp.o
Compiling .pioenvs/luxeflex-trap/FrameworkArduino/spiffs/spiffs_nucleus.cpp.o
Compiling .pioenvs/luxeflex-trap/FrameworkArduino/spiffs_api.cpp.o
Compiling .pioenvs/luxeflex-trap/FrameworkArduino/sqrt32.cpp.o
Compiling .pioenvs/luxeflex-trap/FrameworkArduino/stdlib_noniso.cpp.o
Compiling .pioenvs/luxeflex-trap/FrameworkArduino/time.cpp.o
Compiling .pioenvs/luxeflex-trap/FrameworkArduino/uart.cpp.o
Compiling .pioenvs/luxeflex-trap/FrameworkArduino/umm_malloc/umm_info.c.o
Compiling .pioenvs/luxeflex-trap/FrameworkArduino/umm_malloc/umm_integrity.c.o
Compiling .pioenvs/luxeflex-trap/FrameworkArduino/umm_malloc/umm_local.c.o
Compiling .pioenvs/luxeflex-trap/FrameworkArduino/umm_malloc/umm_malloc.cpp.o
Compiling .pioenvs/luxeflex-trap/FrameworkArduino/umm_malloc/umm_poison.c.o
Compiling .pioenvs/luxeflex-trap/FrameworkArduino/wpa2_eap_patch.cpp.o
Archiving .pioenvs/luxeflex-trap/libFrameworkArduino.a
Indexing .pioenvs/luxeflex-trap/libFrameworkArduino.a
remove_scanf_float_flag([".pioenvs/luxeflex-trap/firmware.elf"], [".pioenvs/luxeflex-trap/src/esphome/components/a4988/a4988.cpp.o", ".pioenvs/luxeflex-trap/src/esphome/components/adc/adc_sensor_common.cpp.o", ".pioenvs/luxeflex-trap/src/esphome/components/adc/adc_sensor_esp8266.cpp.o", ".pioenvs/luxeflex-trap/src/esphome/components/api/api_buffer.cpp.o", ".pioenvs/luxeflex-trap/src/esphome/components/api/api_connection.cpp.o", ".pioenvs/luxeflex-trap/src/esphome/components/api/api_frame_helper.cpp.o", ".pioenvs/luxeflex-trap/src/esphome/components/api/api_frame_helper_noise.cpp.o", ".pioenvs/luxeflex-trap/src/esphome/components/api/api_pb2.cpp.o", ".pioenvs/luxeflex-trap/src/esphome/components/api/api_pb2_dump.cpp.o", ".pioenvs/luxeflex-trap/src/esphome/components/api/api_pb2_service.cpp.o", ".pioenvs/luxeflex-trap/src/esphome/components/api/api_server.cpp.o", ".pioenvs/luxeflex-trap/src/esphome/components/api/list_entities.cpp.o", ".pioenvs/luxeflex-trap/src/esphome/components/api/proto.cpp.o", ".pioenvs/luxeflex-trap/src/esphome/components/api/subscribe_state.cpp.o", ".pioenvs/luxeflex-trap/src/esphome/components/binary_sensor/automation.cpp.o", ".pioenvs/luxeflex-trap/src/esphome/components/binary_sensor/binary_sensor.cpp.o", ".pioenvs/luxeflex-trap/src/esphome/components/binary_sensor/filter.cpp.o", ".pioenvs/luxeflex-trap/src/esphome/components/button/button.cpp.o", ".pioenvs/luxeflex-trap/src/esphome/components/captive_portal/captive_portal.cpp.o", ".pioenvs/luxeflex-trap/src/esphome/components/copy/sensor/copy_sensor.cpp.o", ".pioenvs/luxeflex-trap/src/esphome/components/cover/cover.cpp.o", ".pioenvs/luxeflex-trap/src/esphome/components/esp8266/core.cpp.o", ".pioenvs/luxeflex-trap/src/esphome/components/esp8266/gpio.cpp.o", ".pioenvs/luxeflex-trap/src/esphome/components/esp8266/helpers.cpp.o", ".pioenvs/luxeflex-trap/src/esphome/components/esp8266/preferences.cpp.o", ".pioenvs/luxeflex-trap/src/esphome/components/esp8266/printf_stubs.cpp.o", ".pioenvs/luxeflex-trap/src/esphome/components/esp8266/waveform_stubs.cpp.o", ".pioenvs/luxeflex-trap/src/esphome/components/esphome/ota/ota_esphome.cpp.o", ".pioenvs/luxeflex-trap/src/esphome/components/gpio/binary_sensor/gpio_binary_sensor.cpp.o", ".pioenvs/luxeflex-trap/src/esphome/components/homeassistant/time/homeassistant_time.cpp.o", ".pioenvs/luxeflex-trap/src/esphome/components/json/json_util.cpp.o", ".pioenvs/luxeflex-trap/src/esphome/components/light/addressable_light.cpp.o", ".pioenvs/luxeflex-trap/src/esphome/components/light/automation.cpp.o", ".pioenvs/luxeflex-trap/src/esphome/components/light/esp_color_correction.cpp.o", ".pioenvs/luxeflex-trap/src/esphome/components/light/esp_hsv_color.cpp.o", ".pioenvs/luxeflex-trap/src/esphome/components/light/esp_range_view.cpp.o", ".pioenvs/luxeflex-trap/src/esphome/components/light/light_call.cpp.o", ".pioenvs/luxeflex-trap/src/esphome/components/light/light_color_values.cpp.o", ".pioenvs/luxeflex-trap/src/esphome/components/light/light_effect.cpp.o", ".pioenvs/luxeflex-trap/src/esphome/components/light/light_json_schema.cpp.o", ".pioenvs/luxeflex-trap/src/esphome/components/light/light_output.cpp.o", ".pioenvs/luxeflex-trap/src/esphome/components/light/light_state.cpp.o", ".pioenvs/luxeflex-trap/src/esphome/components/logger/logger.cpp.o", ".pioenvs/luxeflex-trap/src/esphome/components/logger/logger_esp8266.cpp.o", ".pioenvs/luxeflex-trap/src/esphome/components/logger/select/logger_level_select.cpp.o", ".pioenvs/luxeflex-trap/src/esphome/components/logger/task_log_buffer_zephyr.cpp.o", ".pioenvs/luxeflex-trap/src/esphome/components/md5/md5.cpp.o", ".pioenvs/luxeflex-trap/src/esphome/components/mdns/mdns_component.cpp.o", ".pioenvs/luxeflex-trap/src/esphome/components/mdns/mdns_esp8266.cpp.o", ".pioenvs/luxeflex-trap/src/esphome/components/network/util.cpp.o", ".pioenvs/luxeflex-trap/src/esphome/components/ota/ota_backend.cpp.o", ".pioenvs/luxeflex-trap/src/esphome/components/ota/ota_backend_esp8266.cpp.o", ".pioenvs/luxeflex-trap/src/esphome/components/ota/ota_backend_host.cpp.o", ".pioenvs/luxeflex-trap/src/esphome/components/output/automation.cpp.o", ".pioenvs/luxeflex-trap/src/esphome/components/output/float_output.cpp.o", ".pioenvs/luxeflex-trap/src/esphome/components/restart/button/restart_button.cpp.o", ".pioenvs/luxeflex-trap/src/esphome/components/safe_mode/safe_mode.cpp.o", ".pioenvs/luxeflex-trap/src/esphome/components/script/script.cpp.o", ".pioenvs/luxeflex-trap/src/esphome/components/select/select.cpp.o", ".pioenvs/luxeflex-trap/src/esphome/components/select/select_call.cpp.o", ".pioenvs/luxeflex-trap/src/esphome/components/select/select_traits.cpp.o", ".pioenvs/luxeflex-trap/src/esphome/components/sensor/automation.cpp.o", ".pioenvs/luxeflex-trap/src/esphome/components/sensor/filter.cpp.o", ".pioenvs/luxeflex-trap/src/esphome/components/sensor/sensor.cpp.o", ".pioenvs/luxeflex-trap/src/esphome/components/sha256/sha256.cpp.o", ".pioenvs/luxeflex-trap/src/esphome/components/socket/lwip_raw_tcp_impl.cpp.o", ".pioenvs/luxeflex-trap/src/esphome/components/socket/socket.cpp.o", ".pioenvs/luxeflex-trap/src/esphome/components/status_led/light/status_led_light.cpp.o", ".pioenvs/luxeflex-trap/src/esphome/components/stepper/stepper.cpp.o", ".pioenvs/luxeflex-trap/src/esphome/components/switch/automation.cpp.o", ".pioenvs/luxeflex-trap/src/esphome/components/switch/switch.cpp.o", ".pioenvs/luxeflex-trap/src/esphome/components/template/cover/template_cover.cpp.o", ".pioenvs/luxeflex-trap/src/esphome/components/template/switch/template_switch.cpp.o", ".pioenvs/luxeflex-trap/src/esphome/components/text_sensor/filter.cpp.o", ".pioenvs/luxeflex-trap/src/esphome/components/text_sensor/text_sensor.cpp.o", ".pioenvs/luxeflex-trap/src/esphome/components/time/automation.cpp.o", ".pioenvs/luxeflex-trap/src/esphome/components/time/posix_tz.cpp.o", ".pioenvs/luxeflex-trap/src/esphome/components/time/real_time_clock.cpp.o", ".pioenvs/luxeflex-trap/src/esphome/components/version/version_text_sensor.cpp.o", ".pioenvs/luxeflex-trap/src/esphome/components/web_server/list_entities.cpp.o", ".pioenvs/luxeflex-trap/src/esphome/components/web_server/ota/ota_web_server.cpp.o", ".pioenvs/luxeflex-trap/src/esphome/components/web_server/web_server.cpp.o", ".pioenvs/luxeflex-trap/src/esphome/components/web_server_base/web_server_base.cpp.o", ".pioenvs/luxeflex-trap/src/esphome/components/wifi/wifi_component.cpp.o", ".pioenvs/luxeflex-trap/src/esphome/components/wifi/wifi_component_esp8266.cpp.o", ".pioenvs/luxeflex-trap/src/esphome/components/wifi_info/wifi_info_text_sensor.cpp.o", ".pioenvs/luxeflex-trap/src/esphome/components/wifi_signal/wifi_signal_sensor.cpp.o", ".pioenvs/luxeflex-trap/src/esphome/core/application.cpp.o", ".pioenvs/luxeflex-trap/src/esphome/core/color.cpp.o", ".pioenvs/luxeflex-trap/src/esphome/core/component.cpp.o", ".pioenvs/luxeflex-trap/src/esphome/core/component_iterator.cpp.o", ".pioenvs/luxeflex-trap/src/esphome/core/controller_registry.cpp.o", ".pioenvs/luxeflex-trap/src/esphome/core/entity_base.cpp.o", ".pioenvs/luxeflex-trap/src/esphome/core/gpio.cpp.o", ".pioenvs/luxeflex-trap/src/esphome/core/helpers.cpp.o", ".pioenvs/luxeflex-trap/src/esphome/core/log.cpp.o", ".pioenvs/luxeflex-trap/src/esphome/core/lwip_fast_select.c.o", ".pioenvs/luxeflex-trap/src/esphome/core/scheduler.cpp.o", ".pioenvs/luxeflex-trap/src/esphome/core/time.cpp.o", ".pioenvs/luxeflex-trap/src/esphome/core/time_64.cpp.o", ".pioenvs/luxeflex-trap/src/esphome/core/util.cpp.o", ".pioenvs/luxeflex-trap/src/main.cpp.o"])
ESPHome: Removing _scanf_float (saves ~8KB flash)
Linking .pioenvs/luxeflex-trap/firmware.elf
RAM: [===== ] 45.7% (used 37404 bytes from 81920 bytes)
Flash: [===== ] 54.8% (used 572125 bytes from 1044464 bytes)
Building .pioenvs/luxeflex-trap/firmware.bin
esp8266_copy_factory_bin([".pioenvs/luxeflex-trap/firmware.bin"], [".pioenvs/luxeflex-trap/firmware.elf"])
esp8266_copy_ota_bin([".pioenvs/luxeflex-trap/firmware.bin"], [".pioenvs/luxeflex-trap/firmware.elf"])
========================= [SUCCESS] Took 91.05 seconds =========================
INFO Build Info: config_hash=0xbf8154e8 build_time_str=2026-03-22 10:49:41 +0100
INFO Successfully compiled program.
INFO Connecting to 192.168.1.19 port 8266...
INFO Connected to 192.168.1.19
INFO Uploading /data/.build/luxeflex-trap/.pioenvs/luxeflex-trap/firmware.bin (576272 bytes)
INFO Compressed to 399176 bytes
Uploading: [============================================================] 100% Done...
INFO Upload took 4.81 seconds, waiting for result...
INFO OTA successful
INFO Successfully uploaded program.
INFO Starting log output from 192.168.1.19 using esphome API
INFO Successfully resolved luxeflex-trap @ 192.168.1.19 in 0.000s
WARNING Can't connect to ESPHome API for luxeflex-trap @ 192.168.1.19: Timeout while connecting to [AddrInfo(family=<AddressFamily.AF_INET: 2>, type=<SocketKind.SOCK_STREAM: 1>, proto=6, sockaddr=IPv4Sockaddr(address='192.168.1.19', port=6053))] (TimeoutAPIError)
INFO Trying to connect to luxeflex-trap @ 192.168.1.19 in the background
