Above my bathroom mirror I have ten light bulbs, and it got me thinking to use them as a binary display.
The script below takes a number as an input, and displays it in binary on the group light.light_group. It is set to work with bulbs in ascending order from right to left, but removing “reverse” from the lights variable will accommodate a descending order.
When calling it, pass a number:
action: script.binary_number_display
number: 42
If you were to have a light timer, this action would display the current elapsed time in seconds:
number: >-
{{ ((state_attr('timer.light_timer', 'finishes_at') | as_datetime |
as_local - now()).total_seconds() | int ) }}
It is quite niche, but that’s the point of it, isn’t it? ![]()
alias: Binary Number Display
description: Binary Number Display on Light Group
fields:
number:
description: Number to display
sequence:
- variables:
lights: >-
{{ expand('light.light_group') | map(attribute='entity_id') | sort |
reverse | list }}
bin: "{{ '{:0{}b}'.format(number, lights | length ) | list }}"
- repeat:
for_each: "{{ lights }}"
sequence:
- variables:
bit: "{{ bin[repeat.index - 1] }}"
entity: "{{ repeat.item }}"
- choose:
- conditions:
- condition: template
value_template: "{{ bit == 1 }}"
sequence:
- target:
entity_id: "{{ entity }}"
action: light.turn_on
transition: 1
- conditions:
value_template: "{{ bit == 0 }}"
sequence:
- target:
action: light.turn_off
