I am setting up a Wemos D1 Mini that I ultimately want to use as a dimmer for lights defined on HASS but I’m struggling to understand the logic.
The test ESPHome code for the D1 Mini is:
esphome:
platform: ESP8266
board: d1_mini
wifi:
ssid: "Secret"
password: "VerySecret"
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
binary_sensor:
- platform: gpio
pin:
number: D1
mode: INPUT_PULLUP
inverted: TRUE
device_class: door
- platform: gpio
pin:
number: D2
mode: INPUT_PULLUP
inverted: TRUE
device_class: door
This works and I can use the state changes in HASS to switch lights on and off. I now want to differentiate between long and short presses of the switches and found the ESPHome automation page and code on the binary sensor page https://esphome.io/components/binary_sensor/index.html
I understand that the automation code runs on the ESP device itself, not HASS like this sample code
on_multi_click:
- timing:
- ON for at most 1s
- OFF for at most 1s
- ON for at most 1s
- OFF for at least 0.2s
then:
- logger.log: "Double Clicked"
- timing:
- ON for 1s to 2s
- OFF for at least 0.5s
then:
- logger.log: "Single Long Clicked"
- timing:
- ON for at most 1s
then:
- logger.log: "Single Short Clicked"
That logger.log command runs on the ESP8266 as far as I can tell. Is it possible to use this approach to run differing automations on HASS? If so, any pointers would be much appreciated.
Thanks.
Richard
