Hello. I have a problem with setting up a binary sensor with ping. This is my yaml:
configuration.yaml:
binary_sensor: !include binary_sensor.yaml
binary_sensor.yaml:
########## binary_sensor.yaml ##########
# TV On Detection
- platform: ping
scan_interval: 1
host: 192.168.1.69
And log looks like this
journalctl -u home-assistant | grep ping
Feb 26 18:02:21 DietPi systemd[1]: Stopping Home Assistant...
Feb 26 18:02:38 DietPi homeassistant-start.sh[13436]: 2018-02-26 18:02:38 INFO (MainThread) [homeassistant.loader] Loaded binary_sensor.ping from homeassistant.components.binary_sensor.ping
Feb 26 18:02:38 DietPi homeassistant-start.sh[13436]: 2018-02-26 18:02:38 INFO (MainThread) [homeassistant.components.binary_sensor] Setting up binary_sensor.ping
Theres no more info about this sensor, and its reporting offline constantly
Which is weird, because host is up
Any clues what is going on? Please help me.
I want to track my Android TV. Maybe you have some other idea how to acheive this?
In fact, setting this up as device_tracker works, but I do not like the way how it presents the data: home, not home. Device tracker is not intendent to do stuff like that
Definitely, the sensor shows itself on UI so I assume that the config is okay. IN face, I have many separate yaml’s, each preceded with the same heading and everything works. Only this ping sensor do not want to work
Yes, as I said, the host is responding, response times are arounf ~1-3 miliseconds. I’m not home right now so the tv is turned off. I changed the IP to router’s IP and it still shows as unavailable.
ping 192.168.1.254
PING 192.168.1.254 (192.168.1.254) 56(84) bytes of data.
64 bytes from 192.168.1.254: icmp_seq=1 ttl=64 time=0.767 ms
64 bytes from 192.168.1.254: icmp_seq=2 ttl=64 time=0.756 ms
64 bytes from 192.168.1.254: icmp_seq=3 ttl=64 time=0.855 ms
64 bytes from 192.168.1.254: icmp_seq=4 ttl=64 time=0.757 ms
